First post, by Neville
OK, I imagine this has been asked before, but still... in my collection of DOS games that I run with DOSBox, there are two games that never seem to work properly, no matter what configuration I try with them. They're always either too slow or too fast.
1) RoboCop by Data East (EGA, 1989):
2) Test Drive 3 by Accolade (VGA, 1990)
I've tried everything with these, from using the configs rcblanke added to DBGL to trying to figure out the expected CPU/Mhz from their release year.
Any volunteers?
Reply 1 of 6, by bregolin
Have you tried adjusting cycles on the fly while the games are running?
IBM Aptiva 2162 - P55 166 MMX, 32MB, CS4237B + Wavetable, ATI Mach64 2MB / Win98SE
Custom PIII 750, 64MB, SB AWE64, Voodoo 3 3000 AGP / Win98SE
Sony Vaio z505 SuperSlim - PIII 550, 192MB, YMF744, NeoMagic 256AV+ / Win98SE
Reply 2 of 6, by Neville
Yes, although that method strikes me as inaccurate. I'd rather use figures based on something.
Using this method, "RoboCop" seems playable at around 200-700 cycles. And "Test Drive II" at around... I'd be damned, 3000 cycles!
I'd still like to hear other opinions, really. Even better if it's people who played the games on real hardware.
Reply 3 of 6, by NewRisingSun
The problem is that with DOSBox not directly emulating bottlenecks such as the slowness of video memory, there is no direct translation of release year/MHz to DOSBox cycles. Finding a good cycle value has to be done empirically; there is no MHz-to-cycles formula that is "accurate".
I remember back in 1993 that Test Drive III played either too fast (with Turbo button on) or too slowly (with Turbo button off). I am pretty sure that there is no computer at which the "seconds" display really counts up at the speed of an actual second while the game still plays at an acceptable speed. The game is just badly-programmed. Not just in terms of speed, and the bionic-mosquito-like engine sound on Adlib, but also in terms of the game world being seemingly drawn at too small a scale, making you feel like you are driving Gulliver's car on the roads of Lilliput.
Reply 4 of 6, by Neville
NewRisingSun wrote on 2021-01-03, 19:27:
Yes, I can understand that. Still, an aproximated value can be figured out. If you've used DBGL, the author created a few templates based on actual computer models, and those can be very useful. They've saved my bacon more than once, believe me.
Very interesting. I hadn't contemplated the possibility that the game was just badly programmed. And it's not like I haven't seen a few examples over the years.
Reply 5 of 6, by NewRisingSun
If you have not already done so, be sure to obtain the version 2.0 of the game Test Drive III, which allows you to select the sensitivity of the steering wheel by pressing F3. I have found that helps a lot at making the game at least somewhat enjoyable.
