First post, by Furexus
Hey everybody,
I'm trying to emulate the somehow obscure game Storm Master in DosBox, which gives me crackling or no sound, depending on the settings. The game is not listed in the DosBox compatibility list, maybe due to it's rather obscure status. I'm pretty sure I exhausted the usual suspects in the settings for this, but maybe there is something I haven't thought of. Also, maybe a dev wants to check what is the underlying issue. It's not terribly important, but I thought I give it a shot.
Stuff I've tried:
- Setting the cycles to fixed 25000 / 50000 (25000 and lower does nothing, 50000 removes the sound from intro and gives better sound effects in general, but there is still a lot of crackling going on. Also I think it cuts of sound (church scene, you need to construct a church and go in there with the ecclesiast) which should be played in different channels.)
- Setting the display to surface
- Change the machine type to pentium_slow
- Chance the core to normal instead of auto
- Disable XMS/EMS
- Tried Loadfix 127KB
- In Audio tried reducing the samplerate/oplrate to 22050
- In Audio tried to select different cards (sb1, sb2, sb16)
- Changed OPL-mode (often leads to no sound at all)
- Increased Prebuffer to 80
- Tried to increase (up to 8192) and decrease (256) buffer size
- Tried changing adress, IRQ, DMA
With so many options I obviously didn't try every possible combination, so like I said, maybe I overlooked something, but at least I tried to change everything.
Thanks in advance for your help!
