First post, by MrJustAGuy
So here's the situation: I run DOSBox with Wing Commander 3. Everything seems fine through installation except for when I choose to save settings and run the game, it says it can't make a save directory. I am confused...
Reply 1 of 4, by HunterZ
What version of DOSBox?
Reply 2 of 4, by icemann
Wrong forum. Games posts go in the games forum.
Two stones, two crosses, the rest is just icing. - 7th Guest
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
how did you mount everything ?
try createing a save folder or a savegame folder
Water flows down the stream
Reply 4 of 4, by HunterZ
Without more info, there could be many possibilities, including:
- Save directory is read-only
- DOSBox version is too old and may have problems creating new files/directories
- You may be trying to save to a CD or other read-only filesystem
- Your mount setup may be weird
- Who knows...
