First post, by badflame
Hi,
I can't eliminate flickering ingame in VGA mode. It is very evident also on the splash screen, when you see the plane flying, or for example when we show the game map from the menu.
I have tried several alternative versions of DosBox and it still happens.
In fact, even in the online version (VGA) of archive.org the same thing happens.
Any specific parameter to touch to correct it?
Thank you.
