Guide - Windows 95 on DOSBox 0.74
Reply 40 of 123, by Jorpho
ppgrainbow wrote:
Thanks. Do you mean the original release of Windows 95 or Windows 95 OEM Service Release 1?
Wikipedia says, "OSR1 was the OEM release that was identical to Windows 95 retail with Service Pack 1 applied". OSR2 is something very different.
Reply 41 of 123, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Hmm actually the one I've been using all the time says version 4.00.950B
1+1=10
Reply 42 of 123, by robertmo
98se works here too 😀
Reply 43 of 123, by MediaVistaIntel
Hi how to install Windows 98 on dosbox with 3dfx video cards as follows
DOSBox "Next-Gen" ?
Reply 44 of 123, by butterfly
According to this thread you can make a hard drive image of 503Mb. I tried it, it works. I thought this could be useful considering disk space is never enough, specially with Windows
Maximum HardDisk size emulation.
Reply 45 of 123, by valnar
I followed this guide and got everything working with my installation of Win95 in DOSBox, except all drives are in compatibility mode. Loading the Standard IDE driver for Windows doesn't seem to help. I am using ykhwong's latest version.
Is this normal, or is there a trick to make it 32-bit?
Reply 46 of 123, by wd
Rank DOSBox Author
DOSBox Author
Where's the problem?
Reply 47 of 123, by DosFreak
Install Vmware.
Install Windows 95.
TADA!
Make your games work offline
Reply 48 of 123, by valnar
DosFreak wrote:
Install Vmware.
Install Windows 95.
TADA!
I already have a Win95 VMware VM. I'm not talking about that.
I'm surprised by your response DOSFreak since you have participated in Win95-on-DOSBox discussions before.
Reply 49 of 123, by wd
Rank DOSBox Author
DOSBox Author
Since the question remains unanswered:
Reply 50 of 123, by valnar
Pics below
Reply 51 of 123, by wd
Rank DOSBox Author
DOSBox Author
I figured that, but where's the actual problem?
Reply 52 of 123, by valnar
I'm not sure I understand your question? I just wanted to know if its possible to *not* have the compatibility issue running Win95. Yes, everything works fine.
Reply 53 of 123, by wd
Rank DOSBox Author
DOSBox Author
There you are.
"compatibility mode" just means it's using int13.
Reply 55 of 123, by valnar
gulikoza wrote:
It is not possible because there is no IDE controler in DOSBox only int13 support.
OK, thanks.
Reply 56 of 123, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Also keep in mind that performance issues for real hardware may not apply with emulation, or at least not to the same extent.
Reply 57 of 123, by Hazekel
DOSFREAK wrote:
Install Vmware.
Install Windows 95.
TADA!
I have been unable to get Windows 98 running through VMware because my boot disk is ... a disk! I made and image of it, but it still doesn't seem to boot right. That is why it would be nice to get a version of Windows 95 or 98 running on my Windows 7 64-bit system, but without CD support the DOSBOX version doesn't sound like much of an improvement.
Any advice?
Reply 58 of 123, by wd
Rank DOSBox Author
DOSBox Author
DOSBox isn't meant for running win9x, neither with nor without cdrom.
Reply 59 of 123, by Quaker766
I find it funny how i ALWAYS get a BSOD (FATAL EXCEPTION 0E 0173:) When it gets to setting up control panel. I mean i installed 95 perfectly before on dosbox. (about a week ago) But now 98 works and 95 doesnt (Damn illegal operations in 98 slow it down) Oh and just now dosbox crahed.hahahah 🤣
