Reply 360 of 965, by robertmo
- l33t++
In my opinion it sounds the same as on my cm32-l
Yep, it's close to LauraBow_CM64 made by Kaminari, but your CM-32L doesn't require any modification of the MIDI file to play it correctly. 😀
Thus, we must find the exact cause of Thunder MS partials abortion. Whereas channel 3 really contains PC message to change Thunder MS into the organ, channels 4 and 5 don't. Nevertheless, both Lightning (chan 4) and Thunder MS (chan 5) shut down approx. simultaneously.
So, if you try to delete each of these SysEx, Pitch Bend, Modulation and Pedal messages sequentially as well as try each of channels 3, 4, 5 solo, maybe it would at last be clearer what your CM-32L does but Munt doesn't. 😀
it looks it is sysex 108 from channel 3
if i remove it, i got it simmilar to munt
Gee, thanks, robertmo! I think we can fight it now...
wrote:I have another bug to report with the complete soundtrack of Colonel Bequest.
At around 08:15, there's a small organ theme which starts with a thunder patch. In Munt, the patch is heavily distorted, saturating the rest of the music for a few seconds. In the console, Munt complaints about insufficient free partials for that patch.
This one seems to be fixed now...
Thanks to Jerome's recent deep researching of the Sysex processing, we now have much more adequate channel assign modeling.
Sorry for not popping up sooner. Great job all around! The partials bug at 8:15 seems fixed indeed.
However, there is still a similar distorsion at 1:15, albeit smaller yet noticeable. I'm not sure what patch is involved, since the console of the latest Munt version is much less verbose than in previous versions (now it only displays "Play SysEx message xxx bytes"). It sounds like a small thunder followed by a low rumble. Do you need a recording?
I'll appreciate any recordings due to I still don't have any LA module for some reason. 😀
Yep, I noticed that distortion caused by Thunder MS, of course. However, IIRC, KG said that Munt plays Thunder MS patch identically to CM-32L. So, maybe we have here another place of partial abortion that Munt ignores. Let's listen to the recordings...
cm32l_cb_1st_thunder
From what I can hear, Munt's partial allocation / abortion algorithm rather very different. This pattern generates a plenty of "... (Thunder MS): Insufficient free partials ..." messages.
It seems that Munt never aborts PLAYING polys, though it aborts RELEASING and HELD ones. In contrast, this Thunder / Lightning pattern contains no polys in HELD / RELEASING state, therefore, Munt never tries to abort them.
This one seems to be resolved...
Good job, works a charm 😀
... but I have yet another one to report! Interesting thing is, to my knowledge it didn't happen in previous versions of Munt. Still the same kind of distorsion produced by a sort of rumble/thunder sound. This one is around 16:10.
Thanks again, Kaminari!
Although, I trust you and I have no problems with Munt recordings 😀 Recordings you make from your CMs are much more valuable 😉
Please check DAC input emulation mode. I encounter similar crackling if turned GENERATION1/2 mode only.
I encountered subtle distortions with other tunes when the mode isn't NICE. This is really strange to me since KG and I crunch almost all out of amp levels emulation. Errors were about +-1 both for synth and PCM partials. Seems like we need to retest with GENERATION 1/2 modes...
I will record the segment ASAP.
In the meantime, you are right, I am using Generation 2 since it is the default setting for the win32 app (I'm not using the win driver) and I suppose it should sound closer to my CM-64 and my CM-500 when I'm making comparison tests.
I tried the Nice setting, and indeed, it sounds perfect! Even some small volume distorsions I could hear before in some tunes disappear when using Nice setting.
Sorry for the delay. Here are the recordings:
o LauraBow_CM64
o LauraBow_Munt (Generation 2)
How is compatibility with a first gen. MT-32? Somebody has posted on QuestStudios that a sound effect in Heart of China is only heard properly on a first generation MT-32. It's the sound effect when you're flying to a location and the postcard gets stamped. I can make a recording if you wish.
Others here could point out an issue in Dune 2 and Willy Beamish. I'm not sure about those.
@Kaminari Redux:
Too bad, the capture you made shows significant differences. We need a detailed analysis of this Thunder patch at the partial level (which is impossible w/o KG's wonder-box).
@endre1952:
Good question... Without a detailed spec, there is almost nothing to do. To succeed, we need a bunch of digital captures of 1st gen. device but the setup we currently have unfortunately involves CM-32L. So, in the nearest time, I doubt we can advance much in the matter 🙁
That's too bad. I guess KingGuppy is still on board, right?
I'd love to hear how he got his digital capturing "wonder-box" being set up.
Still on board but, realistically, probably unable to do any Munt work for another 4 weeks or so. In the mean time, sergm is doing a fantastic job on the new GUI application, so good things are coming.
You can read a bit about the DAC capture method here: Munt development ?
It's not what I'd recommend, though! The whole setup is very, very fragile - physically, electronically and in terms of driver/firmware/USB host interactions (it's almost completely unbuffered). That's why, although I have an MT-32 and could switch back to capturing from it, it's something I want to avoid doing until we're sure we've squeezed absolutely all the information we can get from the CM-32L while the capture's working.
I'm always on the lookout for a better capturing solution at a reasonable price.
I think it will be better to have another "wonder-box" for mt-32 as there will always be someone showing up with a bug from time to time, as no one is able to test all midi games one by one.
