First post, by Tempus
- Newbie
Is it possible to select what soundcard Munt should output sound from, other than when playing songs in the GUI? I tried to select a certain soundcard in the GUI, but it doesn't use that soundcard when I play games in DosBox for instance. I am using Windows 10, and this soundcard I wanted output to is not the default sound. Does Munt output only on default sound, while used in Dosbox?
EDIT: It seems I need the GUI open for it to select the selected sound output. If I close the GUI, Munt will play through default sound device.
