DOSBox-X branch
Reply 720 of 2440, by Gui55
@TheGreatCodeholio:
Regarding the new FDC emulation, are we now supposed to be able to switch multiple floppies under win9x like we can with CD-ROM's (as long as we of-course refresh the Windows Explorer window)? And we will have 32-bit disk access with the floppy controller along with the hard disk, right?
IE 5.5 SP2
Reply 721 of 2440, by truth_deleted
Codeholio is not finished yet according to the latest git updates.
Reply 722 of 2440, by Gui55
Yes, I already knew that. What I'm asking is if those two things is what we will have when he finishes the FDC emulation.
IE 5.5 SP2
Reply 724 of 2440, by Gui55
OH, okay! Now I see where the confusion is. DOSBox SVN (clean vanilla) actually I know does support this, Codeholio must just not be aware, maybe? (see Mounting multiple floppies to same drive (CTRL+F4 Switch))
TheGreatCodeholio wrote:
I recall that DOSBox has never really supported the multiple disk swapping mode unless "boot" is used directly with multiple dis […]
SA1988 wrote:
same thing happens.
I recall that DOSBox has never really supported the multiple disk swapping mode unless "boot" is used directly with multiple disk image files, or if multiple .iso images are given when mounting a CD.
You should be able to do multiple floppies with disk swapping if you do something like:
boot "disk1.img" "disk2.img" "disk3.img" "disk4.img"
It was added to DOSBox vanilla (not just ykhwong's build, read the auto-generated SVN changelog by Qbix) since SVN r3808.
IE 5.5 SP2
Reply 725 of 2440, by truth_deleted
I verified that Codeholio already has that feature in dosbox-x. Test Ctrl-F4 with a few floppy images mounted by the imgmount command to a single drive letter. It will work in the dosbox-x shell.
Reply 726 of 2440, by Gui55
That's true, it works in the shell...... But is it possible for Codeholio to make it so we can some time in the future, just as an idea, to be able to swap multiple floppies under win9x like we can now with CD's?
IE 5.5 SP2
Reply 727 of 2440, by truth_deleted
As shown in the other post, Codeholio is aware of the idea. Even though a floppy drive appears simple because it is an older device, it has been discussed that this emulation is a hard problem. Perhaps we can offer our help to him so he is not shouldering all this work by himself. 😀
Reply 728 of 2440, by Gui55
Good point. We all can still test Codeholio's great work, even if it is just from his earlier VS2008 builds for public use. If he does decide to make another win32 build, after the FDC emulation and whatever else is finished, I'll always be glad to give my input by testing and any bug reporting. 😀
Anyway, keep up the great work you guys!
IE 5.5 SP2
Reply 729 of 2440, by dosquest
Maybe this has been said before, but when I am trying to install windows 3.11 from floppy I cannot eject the first disk because it is still "in use" and since windows looks at only the A:/ drive inserting a diskette into the B:/ drive won't help. Furthermore, I get a C++ error when I try to set the cycles manually, doesn't matter the integer I put in, it crashes.
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 730 of 2440, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You could make images of your floppies and use imgmount to mount them and cycle via ctrl-f4 through them. And why can't you just eject the floppy or rather how do you change floppies to receive that message?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 732 of 2440, by dosquest
As for the halt on cpu cycles?
Reply 734 of 2440, by dosquest
Nope :3
Reply 735 of 2440, by dosquest
It works with DAUM's build, so maybe something got broken in the fork. Or, should I say, modification.
Reply 736 of 2440, by dosquest
Full size
http://postimg.org/image/60y2tbgnp/
Reply 737 of 2440, by dosquest
For those who can't read what it says.
"Debug assertion failed!
Program c:\program files (x86)\dosbox-0.74\DOSBox.exe
File: f:\dd\vctools\crt_bld\self_x86\crt\dbg.cpp
Line 52
Expression: _BLOCK_TYPE_IS_VALID(pHead->nBlockUse)
For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts.
(Press Retry to debug the application)
Reply 738 of 2440, by truth_deleted
The cycles function works fine for me. The error doesn't seem reproducible, at least from the few details given.
Reply 739 of 2440, by dosquest
I am running windows 10 dev preview, x64bit, core i7, ATI 6750m, 16gb ram, lenovo laptop.
