CGA Composite Mode under DOSBOX (Commited r3804)
Reply 740 of 758, by OmegaPC777
VileRancour wrote:
OmegaPC777 wrote:
Hey, can I have that Tandy/PCjr composite patch, please?
As the replies above yours indicate- an accurate Tandy/PCjr patch calibrated from real machines is not yet ready. The best one currently available is the PCjr patch by NRS which can be found on page 35. But while we're at it, since you've been submitting composite CGA shots on MobyGames, I'd urge you to use the latest accurate patch instead of what's in DOSBox SVN. 😉
I just started using that patch you suggested me.
Reply 741 of 758, by VileR
Here is reenigne's improved composite CGA patch updated for current DOSBox SVN (as of r4115).
Refreshers: F12 toggles composite on/off/auto; Ctrl+Alt+F11 cycles through settings to change (CGA model, hue, saturation, contrast, brightness, sharpness); F11/Alt+F11 modify the current setting. You might need to generate a new keymapper file while in machine=cga.
dosbox-r4115-composite-hires.diff
26.04 KiB
421 downloads
dosbox-r4115-composite-hires.zip
1.36 MiB
450 downloads
Since r4095, DOSBox's opengl output can handle >8 bpp inputs, so the emulated composite screen can be aspect-corrected properly now. (The above build also has the enhanced normal scalers, so you can set e.g. "scaler=normal2x forced" and it'll actually have an effect in this mode.)
The color-depth issue was the only disadvantage of this patch vs. DOSBox's existing one. Since that is now solved, I see no real reason why this shouldn't be committed to trunk. 😉
Reply 743 of 758, by VileR
NewRisingSun wrote:
I don't see Tandy/PCjr composite support though. I would say that should be added before "committing to trunk".
That'd be nice. We'd still need the chroma_multiplexer arrays for those machines, so Trixter/reenigne are welcome to indicate here whether they'd appreciate more prodding in the matter. 😁
Reply 744 of 758, by reenigne
I consider myself appropriately prodded. Life is and has been crazy and hectic this past month, but I'll stick another reminder in the calendar for July.
Reply 746 of 758, by MKSheppard
VileR wrote on 2018-06-13, 00:38:
I'm using your trunk now; since it allows me to set sharpness; is there anyway to set all the CGA variables in the config file; e.g.
"Composite ON"
"Early Model CGA"
"Hue 30"
"Sharpness 80"
to save time in entering them all by hand manually?
EDIT: This is what I've got in Wilderness: A survival Adventure.
The composite photo is with the hue adjusted and sharpness as well.
Reply 747 of 758, by VileR
MKSheppard wrote on 2020-09-09, 00:17:
is there anyway to set all the CGA variables in the config file; e.g. […]
"Composite ON"
"Early Model CGA"
"Hue 30"
"Sharpness 80"
The DOSBox devs expressed that they didn't want extra config options, so we didn't add those in.
The enhanced patch still hasn't been merged anyway; if the dev team would indicate that they don't intend to commit it, then we might as well go wild. 😀
Reply 748 of 758, by MKSheppard
You know, I loaded up regular Wilderness in Standard 4 color CGA mode, and then altered the screenshot in Paint Shop Pro to alter the hue by -60 and I got this:
And it fits too well; it makes me wonder if the CGA palettes in-game were chosen deliberately (remember, this was 1985/1986) so that end-users would adjust the hue on their monitors manually to get this effect.
It's been so long (and I was only 6 or 7 during that era of computing), but I do vaguely remember older monitors having hue adjustment (possibly a side effect of many of them being similar to CRT TVs?)
    7.01 KiB
Reply 749 of 758, by VileR
That may be overestimating the effort that went into the artistic decision-making, if there was any... that game was originally an Apple II job, at least according to MobyGames. It was pretty common for folks to just use automated converters when porting graphics to another machine; or in this case just port the vector drawing routines, plug in some numbers for source->target color translation, and call it a day.
The Apple version only uses 4 colors as well, and also has a purple sky. So funnily enough the vanilla RGB CGA version is more faithful to the original.
Reply 750 of 758, by HunterZ
Anyone know if the new M.U.L.E. release on GOG is lacking composite CGA emulation because of a stock DOSBox limitation, or just lazy config settings on GOG's part?
It appears to be another case of a 320x200x4color mode game that is clearly designed with composite in mind, which I seem to remember being the subject of some friction in this thread.
Reply 751 of 758, by HunterZ
HunterZ wrote on 2021-03-01, 17:22:
Update: @xotmatrix on Twitter investigated this and found that the DOSBox 0.74-2 build bundled by GOG is simply incapable of applying composite CGA emulation to MULE. This is what I expected based on my memory that official DOSBox decided not to implement any level of composite CGA support for 320x200 modes for some bizarre reason, despite the fact that I've personally come across probably half a dozen games that would take advantage of it.
https://twitter.com/xotmatrix/status/1370854058161008643
Not that the situation with SVN builds would help GOG any better, as I think you have to hit F12 to force-enable it on DOSBox ECE for example. Probably the correct answer is to implement a machine=cgacomp setting.
Reply 752 of 758, by VileR
Yes, AFAIK DosBox 0.74-2 inherits 0.74's older composite CGA code, so it doesn't have the extra functionality that's already been committed - let alone the latest, even-more-accurate code (available at the top of this page). No idea what ECE is using.
As far as I remember, the reason was that 0.74 used an auto-detect approach, which can't work for 320x200 modes since they don't require a telltale register write, unlike 640x200. Also, supporting them required a different approach and some extra research, which was yet to be done at that point in the ancient past.
Unfortunately, it's probably futile to expect these companies to configure their DOS-era re-releases properly, or even to use an appropriate build of the emulator. 🤬
Reply 754 of 758, by MKSheppard
VileR wrote on 2020-09-11, 00:40:
VileR, I've been reading the Wilderness manual and I found this passage on page 10 of it:
We suggest you use a color monitor or television to more vividly recreate nature. Make sure the tint is adjusted so that the sky is blue and the world appears in its proper hues.
So it looks like that this was the original intent of the designers.
Reply 755 of 758, by pbblair
VileR wrote on 2012-11-09, 04:04:
- F12: set composite output - auto/on/off (default=auto)
- Ctrl+Alt+F11: select CGA model (early/late, aka "old/new")
@VileR The keyboard shortcut for toggling between old and new CGA composite modes (Ctrl-Alt-F11) didn't work for me on a Raspberry Pi. When I press it, the screen goes black, with only a blinking cursor in the top left. The only way to get back to DOSBox is to press Ctrl-Alt-F1, and even then, the CGA mode doesn't actually change.
This is because Linux reserves Ctrl-Alt-F11. In fact, all of Ctrl-Alt -F(x) is reserved. These keyboard shortcuts cycle between different virtual terminals.
In effect, there's no way to switch over to the newer CGA composite mode.
Might I suggest an alternative for a possible patch?
F12: auto / on (early) / on (late) / off
(Alt)-F11 could remain as is, to control hue.
Thanks!
Reply 756 of 758, by VileR
pbblair wrote on 2022-04-16, 20:35:
In that case the 'auto' setting would also need to have the 'early'/'late' duplication. Either way, you seem to be referring to the older version of the patch, which is less accurate/complete and not likely to be worked on further.
On the bright side, you can always change the key assignment in the DOSBox mapper - look for an event "CGA Model" (if you're using the Ctrl+F1 GUI) or "hand_cgamodel" (if you're editing the mapper file directly), and change it from Ctrl+Alt+F11 to something more usable.
Reply 757 of 758, by pbblair
Thanks for the tip about the mapper; that get me a little closer. For best results, it seems like DOSBox-X (and maybe other forks) would solve my problem by providing CONF options, but I'd still love to see an easy-to-use implementation in DOSBox itself.
I've got two Spinnaker Software games, Alphabet Circus and Alphabet Zoo, that look best in "late CGA."
There are actually two issues:
1) "Auto" doesn't trigger composite mode for them. Presumably this is because their specific resolution/color combo can't be auto-detected, as discussed earlier on this page. I tried various combinations of this thread's "register ticking" programs, hoping I could put one in a batch file to execute right before the games, but to no avail. Would something like that theoretically be a solution?
2) Not only must the user (my 3-year-old daughter in this case) press F12 to enable composite, but she must also press some other key or key combo to get into "late composite" for it to look good. This just isn't going to happen. And as I ponder the learning curve for these settings, it seems like the early/late emulation is distinct from all the other controls that correspond to knobs that would have been on composite monitors at the time these games were new. This is why I like the idea of overloading F12, so that someone new to composite CGA could learn "Press F12 until you like how it looks," and could eventually get into the F11 stuff if they want to adjust the (virtual) monitor.
Thanks for any further tips.
