Reply 40 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I am well aware it's not an accurate representation. If nothing else, the RGB modes allow a background color which offers a lot of color artifact possibilities that the mode 6 algorithm won't take into consideration at all. For my part, none of this is intended as a substitute for real support in the emulation. I have to say, though, that Fooblitzky (in particular) works remarkably well with this hack.
Reply 41 of 758, by KiyoteLockeWolf
Someone should put [SOLVED] on the title of this thread now.
I was going to make a joke..
""Well dang it.. I think my enthusiasm just went and exploded.. All I have left is regret and taxes. ~ @what's his name..
Got less and less funny the more I ruminated about it.
More screen shots!!! Want more!
I have to admit.. You're one good ASM programmer. Any tips on learning me a bit up to it too? I'm still crawling.
It's interesting how the colors match lo-res on an apple.
I'm going to work on some games that exploit CGA/NTSC now. Or at least little funny screen savers and odd toys. (Probably a drawing program.)
Does anyone (besides me) still program in BASICA/GWBASIC? This hack is good for tinkering around with in such tinkering ways.
Kiyote!
If it ain't borked, fix it 7 times.. Reinvent the wheel every day. Compile 8085/8086 code daily. Drink lots of instant coffee. Look both ways before cooking a turkey.
Reply 42 of 758, by KiyoteLockeWolf
@ripsaw8080
Dear ripsaw..
I was wondering if you could possibly re-write my bulky TSR into a compact *.COM TSR.
The guts of my COMPCGA3.EXE code that worked well was this.
mem[0:1040]:=(mem[0:1040] and $cf) or $20;
port[$3d8]:=port[$3d8] and 251;
Of all the stuff I coded, this combination is what worked really well.
I included two screen shots of my CGA/NTSC animated GIF decoder I converted.
The framerate is horrid on a regular DOS pc, but in DOSBOX, it's 10 times worse.
I'm going to have to re-write the decoder into a transcoder which will create a 640x200x2 data stream (file) that can be displayed much quicker in DOSBOX.
The snapshots are what it looks like. I did watch an animated GIF under emulation though. Twas interesting.
Kiyote!
    28.67 KiB
    youtube video transcoded into CGA/NTSC
    40.04 KiB
Reply 43 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
That's a pretty simple program, and would be useful practice if you're interested in writing assembly code. BTW, port 0x3d8 always reads 0xff in DOSBox as far as I can tell, so not much reason to read it before writing it.
Reply 44 of 758, by KiyoteLockeWolf
I am finding tutorials on 8086 assembly and stuff that are (for once) really descriptive.
I'm trying to learn. I also found a free 8086 compiler.
Since I couldn't figure it out on my own, (i will learn eventually), would you help me put that into a hotkey (ALT-P) TSR of that code? It would be just like my COMPCGA3.EXE program, where the hotkey triggers the writes to the address and the port, but much much much tinier. Or, could you add a hotkey function to run that bit of code from within your existing TSR? It traps for mode switching, but if I'm running something that doesn't get into those modes, 640x200x2, it stays dormant and the hotkey code would flip it into composite mode for stuff that doesn't venture into mode 4 and mode 5.
If not, don't worry.. I did make COMPCGA3.EXE. It's huge like a rhino, but it DOES work. Plus I have the satisfaction of making it.
BTW,.. what do you think of the screenshots of youtube videos? I'm hoping to have the transcoder and viewer done today.
I'm missing some of my good CGA based games. I gotta go digging to see if I still have some more for some more cool screenshots.
Kiyote!
@everyone else.. ~ more screen shots? plz? kthnx..
Reply 45 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Maybe start another thread for the stuff you're making.
To get this thread back on track for what it was originally about, I've attached a 1 minute video of Fooblitzky running in DOSBox 0.73 with the mode 6 composite hack. It uses DOSBox's zmbv codec and I stripped out the audio to make it much smaller. Comparing how it looks to the screenshots on Mobygames, I think the reason the hack works so well in this case is because although the game uses mode 4, it's all in black and white, and the mode 6 composite palette is highly applicable to black and white.
    fooblitz.zip
    417.97 KiB
    505 downloads
    1 min. movie of Fooblitzky with the mode 6 composite hack
Reply 46 of 758, by KiyoteLockeWolf
Some of those animations in the video remind me of the Monty Python intro.
Kiyote!
Reply 47 of 758, by KiyoteLockeWolf
More CGA screenshots.
    48.64 KiB
    65.86 KiB
    61.77 KiB
    70.16 KiB
    72.09 KiB
Reply 48 of 758, by KiyoteLockeWolf
continued..
    38.16 KiB
    80.48 KiB
    70.17 KiB
    83.93 KiB
    35.22 KiB
Reply 49 of 758, by KiyoteLockeWolf
ZOMG.. MORE!!
I think Dangerous Dave might've been made for CGA/NTSC.
Kiyote!
    63.37 KiB
    68.81 KiB
    19.93 KiB
    64.6 KiB
    50.71 KiB
Reply 50 of 758, by KiyoteLockeWolf
99% of those I used COMP6_2.COM, which is Ripsaw's TSR.
Chess is one of the few I used COMPCGA3.EXE, my TSR on.
Kiyote!
[EDIT]
Actually, Bubble Bobble wouldn't run, period, without Ripsaw's TSR.
I got to level 30.
    98.95 KiB
Reply 51 of 758, by KiyoteLockeWolf
More fun with CGA/NTSC..
Simulated Apple screen!
Kiyote!
[EDIT]
I'm supposed to be getting a real CGA card soon from a friend! YAY!!!
    25.73 KiB
    Simulated Apple screen ~ fake!
Reply 52 of 758, by HunterZ
Took a couple screenshots with Ultima 2, which falls under the same category of these other games. Doesn't look quite right, but arguably better than 4-color CGA I guess.
    3.28 KiB
    4.7 KiB
    3.91 KiB
    4.99 KiB
Reply 53 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
After examining the DOSBox code, I learned that it isn't necessary to switch mode 4 to mode 6 to get composite decoding; just need another port write to generate the composite palette. The attached TSR program will enable the color burst while staying in mode 4, which has the advantage of correct 40-column text instead of the more smeary 80-column text you get with mode 6.
The colors are not accurate for mode 4, and I think that may be for reasons explained here.
We can do slightly better if we sample the signal 1280 times per line instead of 640. This sample rate smoothes out the transitions between colours a little more, but also has the advantage that it allows us to decode colours from modes other than 640x200 palette 15 accurately (something that Dosbox currently does not do).
    COMP4.ZIP
    776 Bytes
    545 downloads
    TSR to enable color burst in CGA mode 4
Reply 54 of 758, by HunterZ
Would that really make a grey dragon green?
Retook the screenshots with the new TSR:
    4.57 KiB
    3.91 KiB
    4.89 KiB
    3.18 KiB
Reply 55 of 758, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The author of the blog I linked (who also made some related comments in an old thread) specifically mentions how certain colors can be confused at a lower sample rate. However, DOSBox's current algorithm may not be entirely applicable to mode 4 for other reasons.
