VIDEO - Direct3D patch (Host)
Reply 80 of 173, by gulikoza
Alright...fixed it 😎
When the lock fails, dosbox will switch to not passing the flag. It seems to work now in w2k.
I'll have the updated patch & build (finally!) up on my page in a few days 😀
http://www.si-gamer.net/gulikoza
Reply 82 of 173, by herman_silver
Ej, nice work "stari".
I'll try to modify the patch when i have time to add some additional features like correct aspect ratio on 1280x1024 LCD's. But maybe you will come ahead of me.
"Nadaljuj z dobrim delom".
Reply 84 of 173, by grifith
I use ykwongs Dosbox CVS and in the last two builds i noticed that using Direct3D as output and setting the window resolution doesn't work anymore.
I usually set 1280x1024 as window resolution but dosbox starts in a 16:9 sized window regardless.
Just to let you know 😉
Reply 85 of 173, by ykhwong
I think it works fine. It is probably due to the recent changes of direct3d code (res part in sdlmain.cpp).
After:
if((sdl.desktop.window.width) && (sdl.desktop.window.height)) {
scalex=(double)sdl.desktop.window.width/(sdl.draw.width*sdl.draw.scalex);
scaley=(double)sdl.desktop.window.height/(sdl.draw.height*sdl.draw.scaley);
if(scalex < scaley) {
sdl.clip.w=sdl.desktop.window.width;
sdl.clip.h=(Bit16u)(sdl.draw.height*sdl.draw.scaley*scalex);
} else {
sdl.clip.w=(Bit16u)(sdl.draw.width*sdl.draw.scalex*scaley);
sdl.clip.h=(Bit16u)sdl.desktop.window.height;
scalex=(double)sdl.clip.w/width;
scaley=(double)sdl.clip.h/height;
} else {
sdl.clip.w=(Bit16u)(width*scalex);
sdl.clip.h=(Bit16u)(height*scaley);
Before:
sdl.clip.h=sdl.desktop.window.height;
scalex=(double)sdl.desktop.window.width/width;
scaley=(double)sdl.desktop.window.height/height;
} else {
Reply 87 of 173, by shaddam
hello ...
want just to bring to notice that with the last DirectX 9.0c redistributeables from Februar 2007 & Dezember 2006, the support for Windows ME, Windows98se, Windows98 & Windows95 was dropped.... 🙁
the last one with support for all of them was October 2006, here they are listed (win98se, ME...)
http://www.microsoft.com/downloads/details.as … &displaylang=en
Februar 2007 (here they are missing)
so... maybe it would be idea for maxium compatiblity to link against the headers from the SDK October 2006 version...
if not a really great functionality arises which is available only in later versions....(don't think so) 😉
Reply 90 of 173, by gulikoza
Thanks to a friend of mine (and Moe!) there's some things coming real soon...who can figure out what's "wrong" with this picture? 😁
    59.54 KiB
Reply 92 of 173, by neules
Hello Glukoza! I have yours DOSBox release with patch (direct3d)
My settings in dosbox.conf:
output=direct3d
pixelshader=scale2x.fx
scaler=none
windowresolution=1024x768
DOSBox says me:
D3D:Pixel shader not needed
Drive C is mounted as local directory
SHELL: Redirect output to nul
D3D: Error in pixel shader shaders\scale2.fx
<1>: error X1507: failed to open source file: 'shaders\scale2x.fx'
Unable to create effect compiler from shaders\scale2x.fx
D3D: Pixel shader output disabled
What's wrong with my dosbox? Why it's don't wanna load pixelshaders?
Please ASAP!
My computer configuration:
AMD Athlon 64 3500+
2 GB DDR400 RAM
256 Nvidia GeForce 6800GT
HDD Samsung 160GB
Soundblaser Audigy
Chipset Nvidia NFORCE3 with AGP
Reply 96 of 173, by `Moe`
It's actually more than hq2x. Think of it as an advanced variant that is based on the same general idea but improves in several details.
Reply 99 of 173, by gulikoza
I have it ready, but I need a few days to put all the other patches together (and wait some time for wd and qbix to commit their pending changes to the cvs 😉)
wd wrote:
Yes it looks better
Current dosbox hq2x algorithm is slightly broken compared to old Moe's patch. See here: Super2xSaI, 2xSaI and SuperEagle
