IPX Help
First post, by DOSBOXER101
Hi
I have two chromebooks, both with ubuntu on it. When I try to play multiplayer games, the ipx won't work.
I did:
Computer 1:
Z:\> ipxnet startserver 2000
IPX Tunneling System utility for DosBox
IPX Tunneling Server started
Z:\>C:
Computer 2:
Z:\> ipxnet connect 123.456.7.89 2000
And it says it fails. What do I do?
Thanks
DOSBOXER101
DOSBOXER101
Reply 1 of 5, by dagrimreefah
What OS does comp 2 have on it? You might have to download some IPX shit for it.
Also, did you forward port 2000?
Reply 2 of 5, by Sammy
did you type the ip of computer1 when you connect with computer2?
Reply 3 of 5, by DOSBOXER101
1. The Second Computer has Chrome OS with XFCE4 on it, and the first Computer has Chrome OS and KDE. Could the OS be the problem?
2. I did the IP of Computer 1 on Computer 2.
DOSBOXER101
Reply 4 of 5, by Sammy
are both pc in the same LAN?
Reply 5 of 5, by dagrimreefah
The OS's should be fine. As the last person queried, are both computers on the same LAN? If they are, I'll also repeat my second question: Is port 2000 open? You can check by google searching "port open test".
