First post, by Heimdall
Heimdall
Offline
On 2 dosboxes I ran "ipxnet server" / "ipxnet connect ...", worked fine, then run on both:
ipxsetup -nodes 2 -deathmatch -altdeath -skill 5 -nomonsters -warp 1
This hapens next (pretty much immediately):
DOOM II Network Device Driver v1.22
Communicationg with interrupt vector 0x60
Console is player 1 of 2 / 2 of 2
Returned from DOOM2.EXE
and returns to DOS prompt. (DOOM2.EXE never seems to get invoked.) If, on the other hand, I run "doom2" or "DOOM2 -warp 1", it works fine.
The folder contains files DOOM2.EXE, DOOM2.WAD, DEFAULT.CFG, SETUP.EXE, IPXSETUP.EXE, SERSETUP.EXE. I tried adding all other files, including MODEM.*, DM.*, documentation etc., but the outcome was the same. I've got the same problem with Doom. What's wrong?
