Reply 36 of 88, by Predator99
This is the required "POWER CARD 5V to 3.3V" I was referring to. I got this one long time ago and now I am happy I have kept it, never knew what is was used for...
Very nice Tyan board.
It seems that your board FSB is clocked more than 68 MHz.
You have two 166 MMX cpu's right?
Optimal frequency is: 66.667 x 2.5 = 166.7 MHz
When it shows 175 MHz at boot screen, (70 x 2.5 = 175 MHz) ,
you'll need then around the minimum of 68.3 MHz and more at the FSB, then it will automatically round up the cpu clock to 175 MHz.
My super socket 7 board has the same behavior. Setting of jumper @ 66Mhz, the clock is between 67.5 and 68.5 MHz mostly.
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
That power card looks very well made. That's a sizable chunk of aluminum for the heatsink so it should operate with decent temps too.
Predator99 wrote on 2021-01-10, 08:19:This is the required "POWER CARD 5V to 3.3V" I was referring to. I got this one long time ago and now I am happy I have kept it, never knew what is was used for...
Interesting - a novelty to me.
It works....! Didnt expect this as its very dirty and some caps look really damaged 😀
Runs only with that power converter card, really lucky I had this one in spare..!
Very nice! Any plans for building a system around it?
No...no time, no space left 😉
I love how the end user is just screwed out of a pci slot.
Its wonderful.
I want it.
Explain this power converter card to me please? That’s just for the pci right? Or for the cpu? So are there unused pins on 5v pci and this card dumps the 3.3v into those pins that were later used for 3.3v in later pci versions?
Does the Tyan S1563 Tomcat Dual Socket 7 AT Motherboard require a power card?
Anyone have one if so?
Also, following this thread with interest.
Also, since there are so many dual boards in this thread, anyone else willing to try this?
Dual AMD K6 computer
Sphere478 wrote on 2021-01-17, 16:48:Explain this power converter card to me please?
The board accepts 3.3V Pentium CPUs, but doesn't have voltage regulators on the motherboard to convert 5v AT power to 3.3V.
Looks like they give you two options:
1) use a power supply that can provide 3.3v and plug 3.3v into the alternate power connectors
-- or --
2) use a voltage regulator card that that fits into a PCI slot. Seems like the card takes current from the PCI 5v pins and feeds it back into the PCI 3.3V pins.
douglar wrote on 2021-01-18, 16:05:The board accepts 3.3V Pentium CPUs, but doesn't have voltage regulators on the motherboard to convert 5v AT power to 3.3V. […]
-- or --
that’s cool. Lol. Thanks for explaining!
Edit: this info ended up not being 100% accurate.
https://www.ultimateretro.net/fr/motherboards/5131
See info file 2.1
OP:
btw incase anyone is wondering
undocumented voltage settings for tyan tomcat s1564 are as follows
vd0 vd1 vd2 vd3
no no no no 1.2v
yes no no no 2.15v
no yes no no 2.25v
yes yes no no 2.35
no no yes no 2.45v
no yes yes no 2.65v
yes yes yes no 2.75v
in addition to documented settings of:
no no no yes 2.8v
yes no no yes 2.9v
no no yes yes 3.2v
yes no yes yes3.3v
no yes yes yes 3.4v
yes yes yes yes 3.5v
as you can see the voltage of 2.15 should be good for k6+ cpus and probably tillamook
it appears there is also a VIO jumper that should be installed for dual voltage chips if i am reading the manual correct.
voltage can be checked between the computer case for ground and the forward most fet where the flat large metal part on the back of the fet is soldered to the board
I think there is a undocumented setting for (yes yes no yes) but didn’t test it. It’s probably one of the mid-high range settings.
fsb setings
j13
50mhz fsb 1-2,3-4
60mhz fsb 3-4
66mhz fsb 1-2
?? mhz fsb no jumper (no post)
?? mhz fsb 2-3 (didn't try)
multiplier settings
j19 j20 j21
1.5x/3.5x no,no,no
2.0x yes,no,no
2.5x yes,yes,no
3.0x no,yes,no
tried dual k62 (one 366 and one 500) both were 2.2v cpus one boots and bios sees as k6, two won't post. performed test on 2.15v and 2x multi(6x setting)
tried a k62+ 570 boots works fine on 2.15v and 2x multi(6x setting) bios detects at 66mhz 486 but it's running at 66x6 (4oo) in reality.
tried a tillamook 266 bios detects as tillamook runs fine at 233 had to jump the pins on the cpu package to get cache working, jumping the pins on the cpu to make 4x work doesn't seem to have worked seems to be at 3.5x
tried a tillamook in primary socket and a 233mmx in the second socket, it boots but no two processor detection in bios
768mb is achievable and stable by installing 128mb edo 60ns simms in slots 3-8 but 1gb will not post using all slots.
This is one of the first Dual S7 boards I got:
In the flesh it´s quite huge.
Thats what she said!
If you decide to let that big beautiful bastard go, let me know!
Will do, but don´t expect that to happen anytime soon 😉
majestyk wrote on 2021-01-29, 15:00:This is one of the first Dual S7 boards I got:
Dude, that board is awesome. It’s not socket 5?
The inclusion of 30 pin simms is confusing me but that does look like a 430hx chipset. Where is your coast module?
That´s dual voltage -> Socket 7.
There are no 30-pin Sockets, they´re all 72-pin SIMM, but the lower four slots provide a 45° position for the RAM sticks.
And you are right about HX!
If memory (sic!) serves me right you need a v.3 (or higher) COAST stick for this board. I have a 512KB stick for this board somewhere.
Thats a really nice board, never seen before. Does it work?
It used to work perfectly when I acquired it about 15 years ago.
However, the Dallas Clock battery (date code 1995) will probably be EOL by now.
I need to fit in a DIL socket and replace the "DS17487-5" which is still being produced and available. If features 4KB of extended NV-SRAM for EISA settings.
I also need a "DS1387 RAMIFIED" (also with 4KB of extended NV-SRAM for one of my FIC EISA boards) that seems to be out of production.
majestyk wrote on 2021-01-30, 08:37:It used to work perfectly when I acquired it about 15 years ago. However, the Dallas Clock battery (date code 1995) will proba […]
I just ordered one of these for my tyan board
https://monotech.fwscart.com/DS12887_RTC_Drop … 4_19810725.aspx
