First post, by Babasha
- Oldbie
Get the party started!
S478 with three ISA-slots, onboard Compact flash?
Need help? Begin with photo and model of your hardware 😉
Aren’t these the boards whereby that’s not a “real” AGP slot, and instead is just a slot for a riser for adding DVI out to the onboard video?
paradigital wrote on 2023-01-09, 20:48:Aren’t these the boards whereby that’s not a “real” AGP slot, and instead is just a slot for a riser for adding DVI out to the onboard video?
Yep! Its a DVI riser-only slot.
ITOX G4V620-B-G S478, ISA, CF slot - first boot at home after recaping!
Modified riser for AGP ADD slot (that slot supports only risers, but not videocards). My “combo” riser add DVI port for integrated videocard and USB5/6 ports. Made it with gameport/usb bracket.
Motherboard setup with basic cable-management and Compact flash PATA SLC SSD 8GB.
