First post, by jasa1063
I picked up a TI486SXL/40 CPU and it came with an interposer board. I suspected it was for cache coherency. I did not use the board, because motherboard I used already had support for a TI486SXL/40. I just did a build with a CH-386-33A/40A motherboard with an Opti 82C391B chipset and 128KB cache. I decided to try the interposer board in this system to see what it would do. I am currently using a 486DCL/40 CPU with no options enabled for A20M, BARB or FLUSH input and I have had absolutely no cache coherency issues. I would be interested if anyone has any information about this interposer board.
    1.72 MiB
    Interposer board bottom view
    1.71 MiB
    Interposer board top view
Reply 1 of 5, by BitWrangler
Interposer is probably the term that would get more recognition.
Reply 3 of 5, by cyclone3d
It looks suspiciously like the Evergreen one shown here:
https://www.ardent-tool.com/CPU/386_upgrade.html#386DX2+
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 5, by Anonymous Coward
Cyrix had a kit that came with one of these too. It was called the 486DRu. The CPU was a regular DLC-40, but their interposer added clock doubling circuitry in addition to the cache coherency.
I guess since you already powered yours on, it probably doesn't clock double since I assume you had your motherboard set for a 40MHz CPU, and doubling to 80MHz would cause the system to not boot up.
I STRONGLY recommend you buy a PGA132 socket to put between this interposer and the socket on your motherboard. These upgrades are known to have fragile pins, and it's easy to snap them off by installing and removing the module too many times.
Reply 5 of 5, by jasa1063
I noticed how fragile the pins were and decided to removed the interposer. I just enabled the FLUSH input and the 486DLC works fine on it's own. I am just going to hold onto the interposer for now.
