Reply 40520 of 58837, by CrFr
Robert B wrote on 2021-09-17, 15:52:
CrFr wrote on 2021-09-16, 20:41:
CrFr wrote on 2021-09-16, 16:01:
Received this Macintosh Plus 1MB today. Everything seems to work perfectly fine, even the external 20MB SCSI hard drive sounds healthy. CRT is very sharp and bright. RAM has been upgraded to 4MB. It's dirty, but not scratched or cracked. I think it will clean up real nice. At price of 45 euros for the whole set, I just couldn't resist 😁
I started taking this thing apart for cleaning. I expected the hard drive to be filled with dust bunnies because of the fan, but no, it looks almost like factory fresh inside. Very minimal dust. Even the fan has almost no dust buildup. This unit must have very low power on hours count.
If in the picture bellow where the red arrows are pointing, there are RIFA 0.01uf , 0.1uf etc capacitors installed, I advice you to replace them ASAP. Those caps are known to fail in kind of a bad way even when they look ok.
EEVblog #1183 - RIFA Madness (Schaffner Repair)
That's very good advice, thanks. The mac itself also has couple of them. They have cracks all over them. I think I'll replace all of those time bombs now that i have everything already disassembled.
Reply 40521 of 58837, by EvieSigma
Caluser2000 wrote on 2021-09-17, 19:46:
EvieSigma wrote on 2021-09-17, 19:32:
I got this interesting Nortel network appliance...thing off eBay, not because I have any real interest in using it for its inten […]
I got this interesting Nortel network appliance...thing off eBay, not because I have any real interest in using it for its intended purpose, but because it's an interesting small form factor PC using (in this case) a 400MHz Socket 370 Celeron CPU. I think this chassis might actually be made by Intel and just OEM'd by Nortel, as I saw one of these machines on eBay once minus the Nortel branding.
Cool. I'm a fan of odd form factors as well. Smaller the better...😉
This thing is roughly 10 inches by 12 inches, which makes it quite small indeed. Not as small as a Mac Mini or a NUC but smaller than most hardware of the late 90s/early 2000s.
Reply 40522 of 58837, by PD2JK
AGP stuff. It won't fit in contemporary desktops without a hammer, so it's retro. 😉
This summers' finds:
The attachment DSC_1174~2.JPG is no longer available
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 40523 of 58837, by Horun
Stumbled on a USB to Serial port adapter using the Prolific PL-2303 for $1 at a thrift store, they first came out about 2002 or before from digging in archive org.
Mine has the PL-2303 H version chip so is only USB 1.1 but figured it might be fun to play with 😀 Has vender ID of USB\VID_067B&PID_2303 // USB\VID_067B&PID_2303&REV_0202
Found old Win 98, XP,etc 32 bit drivers digging around here: http://web.archive.org/web/20060708183356/htt … oad-2.asp?ID=17
Found the drivers for Win9x, Win2k, XP, Win7 32bit/64bit too. http://web.archive.org/web/20110703171921/htt … loads.asp?id=31
Sure glad Archive org is around as could not find much on it without them..
Reply 40524 of 58837, by BitWrangler
You shoulda held out for a USB 3.1 version so it could wait for serial data at 10 gigabits per second. 😉
Yah I picked up similar piece a month or so ago, didn't need to hunt drivers. Windoze and ubuntu both found and configured it.
Reply 40525 of 58837, by Horun
BitWrangler wrote on 2021-09-17, 23:43:
Heheee Yeah if it was USB 3 would would be more thrilled but for a $1 am not complainin and it is sort of vintage being USB 1.1 (first released 1998)
Reply 40526 of 58837, by cyclone3d
Hah... I'm pretty sure there aren't any USB 3 to serial adapters but I could be wrong.
The place I used to work at had some equipment that would only work with genuine serial ports and so when serial went away on most machines it was a pain trying to find a USB to serial adapters that would work properly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 40527 of 58837, by ODwilly
cyclone3d wrote on 2021-09-18, 02:57:
I have a serial PCI card and this is the only reason it's still kicking around. Ya never know when it might be useful!
Reply 40528 of 58837, by Robert B
Creative 3DBlaster GeForce Annihilator - GF256 32MB SDR
Ati Radeon 9600XT 256MB with AC VGA Silencer
Intel 486 DX2 66MHz ES Sk.3
Gigabyte GA-5AX Rev 4.1 - SS7 with mistery K6-2 or (wishful thinking) K6-3. The cooler is stuck firmly and I'll power it up next week to see what's what. 😁 Also it needs a few caps.
Misc. i7-3770K and 6x I5-650 CPUs.
Reply 40529 of 58837, by PTherapist
Couldn't resist another retro purchase, this time an Intellivision -
The attachment 0INTELLIVISION.jpg is no longer available
A console I never owned back in the day, but was curious about.
Bought the console itself as "untested" from eBay for a reasonable price, taking another gamble. I didn't have any games, so bought the cheapest game I could find on eBay - Soccer as pictured above.
I opened up the console first to check for anything nasty, all looked good so I powered it on and it worked!
After some pot tweaking, it's looking as good as can be expected with RF on a modern TV:
The attachment WhatsApp Image 2021-09-18 at 12.07.40.jpeg is no longer available
Reply 40530 of 58837, by Ydee
Robert B wrote on 2021-09-18, 10:31:
Gigabyte GA-5AX Rev 4.1 - SS7 with mistery K6-2 or (wishful thinking) K6-3. The cooler is stuck firmly and I'll power it up next week to see what's what. 😁 Also it need a few caps.
Uh, Ali Aladin V rev.E? I wouldn't mind a K6-2...
Reply 40531 of 58837, by Joakim
Creative 3DBlaster GeForce Annihilator - GF256 32MB SDR Ati Radeon 9600XT 256MB with AC VGA Silencer Intel 486 DX2 66MHz ES Sk.3 […]
Nice SS7 board. I wouldn't mind one of those atx models.
Reply 40532 of 58837, by BitWrangler
Nice stuff Robert..
From the look of the cooler, it's one that came with "pink goo" a thin rubberlike thermal pad that melts into the CPU in use. Best guess is to run it hot, then try to twist it off.
Reply 40533 of 58837, by Robert B
Yeah guys. This is also a first for me. The very first ATX SS7 I own. The jumper settings indicate a K6-2 450 or a K6-3 450. Any way it turns out, this board was a catch no question about it. Also, I'll replace only the caps near the socket and the smaller ones only if needed.
Yeah I think that's it! 😀 Pink goo. I'll submerge the heatsink with the CPU stuck on it in IPA 99% for a few hours and see what I get or I'll make it hot and toasty by running it (although the caps look pretty iffy) or by using very carefully a hair drier, then I'll try to twist it gently.
Reply 40534 of 58837, by PcBytes
I'd go with running the CPU for a good while until it gets hot enough. I know this from the OG Xbox (HUEG) where most people run it enough for the heatsinks to get soft enough to be twisted.
Reply 40535 of 58837, by liqmat
PTherapist wrote on 2021-09-18, 11:18:
Couldn't resist another retro purchase, this time an Intellivision - […]
Oh boy. That rabbiit hole can go VERY deep if you let it. The Mattel Intellivision holds a special place in my history. It was my first console as a kid. Absolutely loved it. If you ever want to see an amazing homebrew scene, Intellivision has a very dedicated bunch that still make high quality games for it to this day. AtariAge.com forums has a very active Intellivision group with some very avid collectors and can help you with pretty much anything related to the console. I mean come on, someone actually figured out how to fit "Defender of the Crown" on that console and was released in 2018. Insane, considering its limitations.
https://youtu.be/M6FnCayEqlM
Reply 40536 of 58837, by dormcat
Tried to find a GeForce 2-4 (non-MX model) as my better AGP cards are Radeon 9600 Pro and 9000 Pro with no table fog support; yet I found an FX 5600 XT (Asus V9560XT) for NT$350 (US$12.5 or €11) from a reputable used computer parts store.
Will try to test nglide on it; any suggestions and tips?
The attachment IMG_20210918_215236.jpg is no longer available
Reply 40537 of 58837, by Salient
Got this for a very good price.
A Roland SC-55 with the "GS Standard" front. It contains ROM version 1.10.
Now I have the GS Standard front with ROM 1.10, the GS front with ROM 1.21 and the GM/GS front with ROM 2.00.
Reply 40538 of 58837, by Locutus
286 "CHIPS" mainboard from TULIP.
Unfortunately dead 🙁
The attachment IMG_1229.jpg is no longer available
