First post, by tabaglio
Greetings!
I recently recovered a box of scrapped boards, some in good shape, some in various state of disassembly. Between these, I found this AT motherboard.
On this HIPPO II 486 rev 2.1 board some components were removed, but given that it is in a very good general shape (and it came with a processor too!) I'd like to give it a chance at life before recovering the components. I'm sure I have better 486 mainboards, but I really hate disassembling things when they still have a chance to work.
809.7 KiB
This board uses an OPTi 82C493/C206/C392 chipset.
What was removed is the following:
- some generic 74' logic chips (already replaced)
- the BIOS chip
- The oscillator at Y2, see photo, bottom of the board. I already put a socket in there so I can try different ones.
The board looks very similar to its successor, the HIPPO III that is documented at http://www.win3x.org/uh19/motherboards/4028, so I guess I can more or less look at that for the jumper settings...
But what I really need is the following:
  • Does anyone have this board and can check the oscillator frequency for me? I couldn't find a photo online, and boards with this chipset come with 33/50/66Mhz oscillators...
  • I could try various bios images of OPTi boards linked at win3x.org, but if someone has a dump for this one, it would be a better option: one less unknown to worry about.
I know it'll be very hard to recover everything necessary to get this board up and running, but hey, at least need to try!
Reply 1 of 8, by tabaglio
In the meantime, it seems the manual is still available here: https://www.elhvb.com/mobokive/Archive/Octek/ … 20II/index.html
[edit]
I was able to get the board to boot using the bios at this page: http://www.win3x.org/uh19/motherboards/1499
[edit 2]
Using a 40Mhz oscillator at Y2 for now. I actually suppose a 33Mhz was in there, but I don't have one around.
I also tried a 50Mhz and a 66Mhz one, but both caused the system not to boot.
Reply 2 of 8, by tabaglio
I think I've also been able to reverse (original was read protected) the PAL16L8 at U52, near the keyboard controller.
Attaching the JED file to burn to a GAL16V8. With this, my board boots fine like with the original,I did not do much more testing though (obviously the board does not work with the chip removed).
    U52.zip
    607 Bytes
    28 downloads
    Octek Hippo II reversed PAL16L8 at U52 (burn to GAL16V8)
Reply 5 of 8, by tabaglio
TheMobRules wrote on 2021-09-19, 18:44:
Nice job! Could you describe the process you followed to reverse that PAL?
Thanks, I developed my own tools for this job: https://github.com/DuPAL-PAL-DUmper/DuPAL_Analyzer
It's basically bruteforcing, followed by a step of manual massaging (mostly to simplify equations that use feedbacks as inputs). I wrote a small explanation here: https://github.com/DuPAL-PAL-DUmper/DuPAL_Ana … ocs/analysis.md.
It's crude, but it does the job for me 😀
Reply 6 of 8, by TheMobRules
tabaglio wrote on 2021-09-20, 00:17:
Awesome! I have a PAL16L8 from a battery-damaged 386 board that I'm restoring (also near the KB controller), it's probably still working but the legs have been deeply affected by corrosion. I will try to fix that by re-tinning the legs but I wanted to try and reverse it just in case I kill it during the restoration process.
I will definitely be taking a look at your work, many thanks!
Reply 7 of 8, by tabaglio
Quick update: I tried various other BIOSes and found out this to work best so far: http://www.win3x.org/uh19/motherboards/1495
The turbo button works, and I also got a performance boost running normally. I suspect cache was not correctly enabled previously.
