VOGONS Driver Library
Reply 1220 of 1658, by Horun
NyLan wrote on 2021-09-23, 21:34:
I just noticed that I've never posted some information I have for my Matsonic build if someone can post them as well :) […]
I just noticed that I've never posted some information I have for my Matsonic build if someone can post them as well 😀
Manual
ms7112c.pdf
Latest Bios : 06302k.BIN (06-30-2000)
Old Bios ( the One I had ) : old.bin
Matsonic 7112c.zip
I will up them later, did upload the Jetway manual to the library today.
Might put the BIOS up too but could not find much info on them, unlike some other companies that give lots of info on their BIOS updates as to what they fix, which flasher to use, etc
Reply 1221 of 1658, by NyLan
Seems the "last" version of the Bios was released quickly by Matsonic.
However, I'm having a "unknown flash type" error message after post with this BIOS. I had to put the "JP7: Flash BIOS Enable/Disable Jumper" to "Enable" to remove this message.
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 1222 of 1658, by Beeman
Greetings all! I cannot get the .7z file on your ATI catalyst drivers collection to open after downloading 3 times and having winrar give me an error on opening file. I noticed the exclamation point in front of the file name and don't know if it is the cause for the winrar error to open file. I even renamed the file after downloading and still no success in opening the archive. Any ideas or can it be put in a .zip format? I appreciate all help and all have a great day! Sincerely, Beeman
Reply 1223 of 1658, by canthearu
Beeman wrote on 2021-09-26, 14:54:
Download and open it in 7zip.
https://www.7-zip.org/download.html
Reply 1224 of 1658, by Horun
canthearu wrote on 2021-09-26, 15:06:
Both Winrar 3.93 and Winrar 5.0 will extract the files w/o changing the name, just tried both....and 7zip will too 😀
Reply 1225 of 1658, by Beeman
Thank you kindly! have a super day!
Reply 1226 of 1658, by Horun
Uploaded all the Media Vision FAQ's I have for a bunch of their cards and kits. Took an hour or so to compile so if it does not work proper let me know...
Reply 1227 of 1658, by Horun
added: http://www.vogonsdrivers.com/getfile.php?file … 6&menustate=0,0
SyQuest SQ3105 and SQ3270 IDE, SCSI and Parallel Port drivers
SyQuest SQ555, SQ5110 and SQ5200 SCSI drivers.
SyQuest Drivers, Faqs and Readme's from 2000-2003 archives.
SyQuest driver version 3.52 dated 8/19/1997.
Includes SQ3105 and SQ3270 IDE and SCSI jumpers and quick manuals.
Note: this was done in a bit of hurry so there may be errors but the files
are all there from the archives and verified good (as far as good when posted and I can test)
Can someone verify the files are ok ??? Please ?
Reply 1228 of 1658, by HanJammer
Horun wrote on 2021-10-17, 03:39:
added: http://www.vogonsdrivers.com/getfile.php?file … 6&menustate=0,0 SyQuest SQ3105 and SQ3270 IDE, SCSI and Parallel Port dri […]
I downloaded it and the zip unpacks fine, files inside the archive seem OK too. Thanks.
Reply 1229 of 1658, by Horun
HanJammer wrote on 2021-10-17, 14:21:
Great, Thanks !
Reply 1230 of 1658, by ntalaec
I have a floppy disk labeled "SQ555 Utility Software release 2.0". It's already included in your upload @Horun?
Reply 1232 of 1658, by Horun
ntalaec wrote on 2021-10-17, 15:33:
If you could Winimage the floppy will post it. Is earlier version than the ones I upped but may be useful !
Added SyQuest EZ135, EZ230, SyJet and SparQ drivers for PC
Reply 1233 of 1658, by ntalaec
Horun wrote on 2021-10-19, 23:43:
OK, I have attached the file to this post.
Reply 1234 of 1658, by Horun
Thanks ! That is the oldest version of Syquest utils have seen. Is v2.0.
Will up it when I get a chance.
Reply 1235 of 1658, by andunn
Driver and BIOS image for Appian Jeronimo J2 graphichs card. It's a dual monitor solution based on two Cirrus Logic CL-GD5462-HC-B Laguna chips on one board.
Driver is for Windows 95 but works for 98 also. The BIOS chip is labeled as version 1.05. Both files are nowhere to be found on the web.
Reply 1236 of 1658, by Heatvent
parshath20 wrote on 2019-02-10, 03:59:
I've been playing around with a Gateway Essentials 500 desktop PC for a little while now, turning it into a retro gaming PC for […]
I've been playing around with a Gateway Essentials 500 desktop PC for a little while now, turning it into a retro gaming PC for some light nostalgia trips. It has an Intel Warm Springs WS440BX motherboard in it and when I received it I noticed that it didn't have the most recent BIOS installed. After checking vogonsdrivers, Gateway support, and Intel support, I couldn't find exactly what I needed. Further digging through Google DID reward me with what I think is the final BIOS version for the WS440BX, being 4W4SB0X0.15A.0019.P14.0005091032.
I flashed it to the board without problems and everything is working great.
I'd like to offer this BIOS update for posting on vogonsdrivers in case anyone needs them in the future. The files included needed to be put on a floppy disk and loaded from DOS, as the disk wasn't bootable and it wouldn't open from Windows. Link below:
https://drive.google.com/open?id=1RX4LeCqdc6F … M7l9sFEVVaZjx0N
Thanks!
Hi parshath20. I am going through a similar search for the latest bios for a Gateway Essential with a "Freeman" motherboard. I can find the support/driver page using the Wayback Machine (https://web.archive.org/web/20030108204723/ht … .asp?pn=2507160), but it looks like Gateway used an FTP site for their files so these were not backed up.
I have Googled around for another option and found the file listed on bios-drivers.com but it doesn't seem to have the file for download ... it just links to download Driver Easy. The latest bios is 4F4JZ0XB.15A.0011.P09 which was included in the file 7507925.exe from Gateway. I haven't been able to track this down elsewhere. Just wondering where you found the bios update for your board?
Thanks!
Reply 1237 of 1658, by PC Hoarder Patrol
Heatvent wrote on 2021-10-28, 14:47:
Hi parshath20. I am going through a similar search for the latest bios for a Gateway Essential with a "Freeman" motherboard. I […]
Thanks!
Thanks!
Try this link - https://web.archive.org/web/20040316221901/ht … reeman/vp09.exe
Reply 1238 of 1658, by Heatvent
Thanks for the link. Just curious how you found this and how to confirm it is the correct bios for the board?
Thanks for your help.
Reply 1239 of 1658, by PC Hoarder Patrol
Heatvent wrote on 2021-10-28, 21:51:
Happy to help 😀 - it's just one of those 'curious' skills you pick up if you're here at Vogons long enough...the ability to track down elusive Gateway BIOS files!!! You're right about their ftp never having been archived by Wayback, but the fact is that many of the same files are scattered across their various http sites, which have been. I have some Wayback links which find me most of what members want, followed by uploads to Vogons Drivers Library and then google searches (frequently results in pointers to driverguide.com).
If you're ever searching again, try one of these links
https://web.archive.org/web/200*/http://www.g … /bios/desktop/* (the one I used this time)
https://web.archive.org/web/20070125165315/ht … esktop_bios.asp (much the same, but laid out in table form)
I do double-check most times just to be sure, and in this case the full BIOS string when vp09.exe is extracted is 4F4JZ0XB.15A.0011.P09.9911011132
