First post, by Wanny
I'm new to this vintage hardware. I got myself a Roland SC-88 some months ago and it was working perfectly until yesterday morning...
I came back from Christmas dinner and wanted to do some stuff with it, but when I turned it on I heard a nasty static sound. If I press the Preview button I can vaguely hear a note, and if I play something through MIDI I can hear notes as well, but with the constant static noise on top.
I replaced the internal battery with a brand new CR2025 (it's the same as a CR2032 but a little thinner) since I was getting a LOW BATTERY message on powerup. The error disappeared but the noise problem persisted.
I found a link for the service manual ( here), followed the instructions for the Test Mode and...
The blinking number is D1, meaning that one of the DRAM chips went bad. According to the service manual it's a M5M44256BJ-7 chip.
Has anyone run into this issue?
___________________________________________
Also, unrelated to the issue, I noticed that the transformer has many voltages (100, 230, 250, etc) next to unused pins. Is it safe to assume that I can desolder the cable from the 110 pin and connect it to the 230 one to avoid having to use stepdown transformers? (we use 230v in my country)
