First post, by mt777
I have ASUS P54NP4 mobo. With 2x P133 - dual cpu is recognized.
But I wanted upgrade them with Overdrive MMX. During booting always 1 cpu is recognized.
Whats' limitation?
Whats' limitation?
The ODPs definitely aren't SMP-capable, I'm afraid. so you are either limited to P200 (non-MMX) or need to upgrade to P55T2P4D or similar motherboard paired with a few regular MMX CPUs.
I thought that Overdrives will be easy upgrade. So will try find P200 (and probably fix multiplier on cpu).
BF1 patched and boots as 200.
I don't have the second cpu now so update topic later after get it.
Works 😀
Thanks dionb for tip.
dionb wrote on 2021-09-28, 00:18:The ODPs definitely aren't SMP-capable, I'm afraid. so you are either limited to P200 (non-MMX) or need to upgrade to P55T2P4D or similar motherboard paired with a few regular MMX CPUs.
What about using interposers along with regular MMX CPUs?
Two P200, nice! 😃👌
cyclone3d wrote on 2021-09-30, 18:26:dionb wrote on 2021-09-28, 00:18:The ODPs definitely aren't SMP-capable, I'm afraid. so you are either limited to P200 (non-MMX) or need to upgrade to P55T2P4D or similar motherboard paired with a few regular MMX CPUs.
Worth a try, I suppose, if you have two.
