First post, by Kahenraz
When using an IDE-to-CompactFlash adatper with my Promise UltraATA133 TX2 IDE controller I found that it will report that my SanDisk Extreme PRO which is a UDMA7 card is not connected with an 80 pin cable and default to Ultra33 (UDMA2) mode.
This is not a problem with my SanDisk Extreme which recognizes as UDMA6 (ATA133).
So if you want to buy the fastest card for your IDE controller it may not necessarily be compatible. These are my only UDMA7 flash cards.
The attachment IMG_20211001_093613_resize_48.jpg is no longer available
The attachment IMG_20211001_180703_resize_19.jpg is no longer available
The attachment IMG_20211001_180610_resize_59.jpg is no longer available
The attachment IMG_20211001_180314_resize_49.jpg is no longer available
Reply 1 of 4, by jmarsh
Did you try running the adapter in 3.3v mode? Some CF cards require it for UDMA.
Reply 3 of 4, by Kahenraz
jmarsh wrote on 2021-10-02, 11:40:
That was a good guess. I moved the jumper to 3.3V but I get the same warning about using an 80 pin cable.
Reply 4 of 4, by Kahenraz
I tried this card in a more modern Socket 775 with onboard IDE where the BIOS also warned that the card is recognized only as UDMA2. I tested this with two different installations of Windows XP: one configured with with ACPI and the other as Standard PC (no ACPI). Even though the BIOS configures card as UDMA2, Windows will correctly detects the card as supporting UDMA6 after booting but only when configured with ACPI. Without ACPI it detects only UDMA2.
I don't know if this is actually related to ACPI or something specific to this board, its VIA chipset, and how Windows XP interacts with it.
