Trouble with Mice on my SOYO 4SA2
First post, by Vipersan
So having recently got DOS622 installed on a 1gb CF card on the SOYO 4SA2..I wanted to add mouse functionality..
You'd think that was straightforward...and it usually is.
I borrowed a working MS serial mouse from a working 386 system...
Plugged a rear panel 9 pin serial port into the serial port 1 header on the mobo and inserted my MS mouse 9.1 floppy in the drive...
It refused at mouse not found ?
I went into the bios and set serial com 1 to auto ...just in case..
Ran up checkit and tested the port..everything passed ..except test modem status...no surprise there.
The serial mouse still connected at this point.
I checked the orientation of the 10 pin header on the mobo ..in case I had it in wrong...referring to the manual.
That was OK...
Neither Checkit nor The MS mouse installation can detect I have a mouse connected ?
This is basic stuff ...but I'm confused.
The mouse itself works on another PC ...The COM port checks out in Checkit..
The ribbon 10 pin to 9 pin serial lead is brand new old stock..?
Any suggestions appreciated.
I could set the com port manually in bios ..
but is there a specific config expected by both checkit and MS mouse 9.1 ?
probably something basic and I missed it ...but I dont usually have problems with mice...
rgds
Reply 1 of 24, by konc
Did the ribbon come with the motherboard? Not all serial connectors on motherboards and I/O cards have the same pinout. There are mainly two common pinouts, maybe your ribbon/connector is not suitable for this motherboard as it is.
Reply 2 of 24, by Vipersan
konc wrote on 2021-10-17, 13:39:
Did the ribbon came with the motherboard? Not all serial connectors on motherboards and I/O cards have the same pinout. There are mainly two common pinouts, maybe your ribbon/connector is not suitable for this motherboard as it is.
Now that I didn't know ...
I'll try and find another to test ..
appreciated..
...and no it didn't come with the motherboard..
Reply 3 of 24, by weedeewee
for your information...
two possible mainboard to DB9 pinouts
    57.3 KiB
    mainboard serial DB9 pinout
Do not ask Why !
Reply 4 of 24, by Vipersan
Thanx for the pinouts Weedeewee...
I'm going to have to make at least another clone of the one I have that works..
I have about 10 of these cables and only one works with the Soyo..
I hope this helps someone else out...because I for one was unaware they were not standard.
rgds and thanx guys..
VS
Reply 5 of 24, by Joseph_Joestar
Interesting, I have the same issue with my Soyo SY-5BT. Both serial cables that I have don't work on it.
I wasn't aware that there were two standards though. I'm guessing Soyo stuck with the older one.
Reply 6 of 24, by weedeewee
Vipersan wrote on 2021-10-17, 14:10:
Someone else posted it here on the forum... after which I reposted it to another thread, where someone noticed a fault with the original, (the pinout names meh)
So this one is with the correct pinout names... I hope 😀 It's always tricky to find good info and since host and device can have different perspectives. oh well 😀
enjoy.
Do not ask Why !
Reply 7 of 24, by weedeewee
Joseph_Joestar wrote on 2021-10-17, 14:16:
I should've removed the old/new reference since they're both old by now.
Do not ask Why !
Reply 8 of 24, by maxtherabbit
weedeewee wrote on 2021-10-17, 14:22:
though I prefer the staggered one.
no leave it, it helps people take an educated guess based on relative equipment age
Reply 10 of 24, by weedeewee
maxtherabbit wrote on 2021-10-17, 14:26:
Vipersan wrote on 2021-10-17, 14:29:
I agree with Max on this ..
it will help as is I think.
I doubt this has truly anything to do with age, just with manufacturing preference, and I also think that the one indicated as new, is actually old.
But it was on the original so, meh :-p
Just looked at my db9 from a 440gx board (late 90's) , and it's the sequential staggered approach
older pentium1 mb cables, also sequential
anyway, measuring where the ground pin db9 pin 5 goes to on the cable should give you an indication and measuring which pin is ground on the mainboard gives you an indication if you have the right cable or not.
the more i look at that picture, the more i want to change it and remove a lot of words :-p
edit: I keep mixing up the two. one preserves the pin numbers on both sides, the other does not. I like the one that preserves the pin numbers. Argh.
Do not ask Why !
Reply 11 of 24, by Nexxen
USB 1.0 had this issue, NC being at the end or in the middle, with different pinouts.
Standards are good sometimes 😀
I've seen PS2 when not connected to the DIN keyboard.
COM too is a new addition to my knowledge, thanks there!!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 13 of 24, by weedeewee
maxtherabbit wrote on 2021-10-17, 15:17:
everything I have is AT/Everex, only even seen the other style once
yes, same here, I like the other style better since it preserves the pin numbering on both sides. this crud is already confusing enough as is 😀
Nexxen wrote on 2021-10-17, 15:17:
USB 1.0 had this issue, NC being at the end or in the middle, with different pinouts. Standards are good sometimes :) I've seen […]
I could add the pinout of my old 8 bit isa card which has all pins in one line... though that would probably differ from board to board.
What the PS2 and DIN do you mean?
Do not ask Why !
Reply 15 of 24, by Nexxen
weedeewee wrote on 2021-10-17, 15:30:
yes, same here, I like the other style better since it preserves the pin numbering on both sides. this crud is already confusin […]
Some baords have AT keyb + PS2 pins.
It happened to me to find 4 or 6 pins and to be different in two boards from different brands.
My quoted sentence came out funny as I wasn't thinking in english.
Reply 16 of 24, by weedeewee
maxtherabbit wrote on 2021-10-17, 15:50:
If any words need to be excised from that image, they are 'sequential' and 'staggered'. Highly ambiguous
Sorry, I still used them 😀
Nexxen wrote on 2021-10-17, 16:17:
Ah, yes, np, the same for the PS2 mouse headers.
Do not ask Why !
Reply 17 of 24, by Vipersan
Well fwiw I now have DOS622 and WIN3 on the CF card ...and mouse control..
Not tried everything as yet ..I'm considering ram expansion from 16mb to 28mb and possibly upping the level2 cache from 256 to 512 if it's doable.
The only bench I've run so far is Superscape (38.4)
what would be the best I could hope for on this 486DX4-100 system ?
Reply 18 of 24, by Tiido
I think I am the one who came up with these some years ago, before I knew there were the AT and Intel names 🤣.
I only ever discovered it when suddenly a COM port mouse stopped working... eventually I found out the shorter and neater COM port breakout I changed to had a different pinout, something I didn't know was a thing until then. It made the most sense to me, one has pins going 12345 6789 on DB9 end, and other 13579 2468, one is sequential, other is staggered... Easy to tell when you lift back the shroud on the DB9 side and that's where the naming came from.
I see seq on almost all my 486 and older stuff, while Pentium1 stuff is almost all staggered, and all newer stuff always staggered, I have even taken time to write a designation on my breakout cables and mobo headers so that things wouldn't be mixed up again. I have an (un)healthy mix of both available 🤣
Reply 19 of 24, by Vipersan
Well I guess I also need to thank you as well then Tildo..
This would have had me confused for days if I hadn't asked..
I guess the moral of the story ...If in doubt risk looking foolish and ask.
added phils collection of benchtests to my CF card..
and of course the first thing I ran was quake
jumpered the turbo header ..and got a respectable 9.8
more experiments to come I think.
