First post, by jheronimus
Hi, all
I'd like to add support for an AMD K6-2/400AFR to my Biostar MB-1575PCT (Socket 5 board with Opti 546/547 chipset and PCI/VLB). The BIOS is AWARD 4.50G.
The CPU I'm going to use is part of an Evergreen Spectra 400 kit, so it is physically and electrically compatible and doesn't need any jumpers set. The system just doesn't turn on with it. It does work with an alternative BIOS from the Edom/WinTech MP039, but that BIOS is otherwise not exactly stable on my board with any CPU.
I've heard that Award BIOS is pretty moddable, so I went through a few tools for that, but I've had no success.
BIOS Patcher 4.23, 4.51 and 6.0 alpha all give me the same error:
Found 1Mbit BIOS!
Can`t find "*BBSS*"!
error - cant find start.modul!error!
As far as I understand, that just means my version of Award is just too ancient for BIOS Patcher.
I've also tried CBROM 2.08, here's the output:
CBROM V2.08 (C)Award Software 2000 All Rights Reserved.
******** 1500PCT.BIN BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
0. System BIOS FFFFFFFFh(-0.00K)10000h(64.00K)ˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇ≤ÄË
Total compress code space = 10000h(192.00K)
Total compressed code size = 10000h(64.00K)
Remain compress code space = 00000h(0.00K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
00000000 00000000| 00000000 00000000 0000 0000
00000000 00000000 0000 0000 |
Modbin works, but I can't see how I can add any features using it — it primarily just allows me to change existing options.
Are there any other tools I could try?
MR BIOS catalog
Unicore catalog
Reply 1 of 37, by jakethompson1
Do you have a POST card and if so does it show any codes with the K6-2? That could give a hint as to how far into the BIOS the CPU check occurs.
Reply 2 of 37, by soggi
The * BBSS * (Boot Block structure signature) tag is an integral attribute of the BIOS boot block. Older AwardBIOS core releases simply don't have it. The BIOS Patcher doesn't work with such BIOSes.
Just to clarify:
Modbin can be used for changing/(un)hiding options and such stuff.
CBROM can be used for adding/removing BIOS modules.
If you want to add CPU support, you have to dig deeper (like BIOS Patcher does).
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 3 of 37, by rmay635703
We should invite someone from wimsbios over here considering how many bios modifications everyone would like to make
Reply 4 of 37, by Nexxen
rmay635703 wrote on 2021-10-24, 18:43:
If anyone decided to create a BIOS modifier it would sell like crazy.
I'd buy a license immediately.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 5 of 37, by mockingbird
Nexxen wrote on 2021-10-24, 18:49:
Your niche and isolated needs don't dictate market trends. The reason why these sort of mods are far, few and in-between is because they are difficult and time consuming, and require an in-depth knowledge of an arcane and long-gone architecture.
No one is going to do that for you, for the $10 license fee he might collect, while you're out at your day job earning a salary for sitting around and fanning yourself.
(Decommissioned:)
Reply 6 of 37, by Roman555
jheronimus wrote on 2021-10-24, 14:34:
IDA disassembler (free version) and AWARD Modular BIOS source code that was leaked years ago.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 7 of 37, by BitWrangler
soggi wrote on 2021-10-24, 17:43:
The * BBSS * (Boot Block structure signature) tag is an integral attribute of the BIOS boot block. Older AwardBIOS core releases […]
Just to clarify:
kind regards
soggi
I'm trying to figure out how I did that with those two tools then. 20 years since I messed with it, so rusty memory problems. I put K6-2 support into BIOSes by copying modules from other BIOSes. Did it only work because board had K6 support in the first place, or that I used a whole chunk from a substantially similar board so the chipset code was right also??
But in this sitch, I'd be planning on starting with the BIOS that worked, not the one that didn't.
Reply 8 of 37, by jakethompson1
BitWrangler wrote on 2021-10-24, 19:52:
Just to clarify:
kind regards
soggi
4.50G is a very old Award BIOS version. I think it's the first version that went from that weird blue-background full screen POST screen to the "Award Modular BIOS, an Energy Star Ally" one. It's quite possible that CPU support was less, well, modular in this older version. I suspect there is a table of known CPUIDs or such in there somewhere, thus the suggestion to see what POST codes it generates. When digging through the code in these BIOSes you can see the POST codes being generated and that's often the best clue to what is going on.
Reply 9 of 37, by maxtherabbit
Just to clarify:
kind regards
soggi
Forgive my ignorance but what is 'bios patcher' ? Is that a specific utility?
Reply 10 of 37, by soggi
Maybe you just had the luck, I can't imagine this works every time - you could be right with your guesses. I've seen BIOSes with a lot of modules and others with just two. But don't take this for granted as I didn't work on something like that for a while (I want to get deeper into all of this, but time is a rare commodity).
maxtherabbit wrote on 2021-10-24, 20:09:
BIOS Patcher is a utility provided by https://www.rom.by/ and especially developed by a user named "apple_rom". It is a tool for automated BIOS hacking/optimizing. With this tool you don't need special skills (programming, HEX, BIOS architecture, ...) to do standard work like removing known bugs (i.e. removing 32G or 65G HDD limit), adding CPU support (MMX, SSE, micro codes) and other stuff. A typical BIOS Patcher log looks like this:
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses|
Attention! Advanced qualification is required!
Found 1Mbit Award BIOS!
Can`t found unpak_sub!
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : is not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: -> fixed.
UDMA66/100/133 on UDMA33_only_MB patch: not found.
Unfortunately, development has stopped many years ago.
kind regards
soggi
Reply 11 of 37, by Ydee
Hi, all […]
Hi, all
Found 1Mbit BIOS!
This seems strange to me - patcher reports 1 Mbit BIOS (128 kB) and in Cbrom the compressed space size is 192 kB, code 64 kB and free space 0! kB? What kind of EPROM is there?
Reply 12 of 37, by soggi
Maybe an older version of CBROM is needed for AwardBIOS 4.50G images!? Version 2.08 is one of the later ones (latest I know is 2.20).
kind regards
soggi
Reply 13 of 37, by jheronimus
I'll do, actually. I'll have to check that.
Not sure what you mean, it's just a pretty standard 128KB ROM file.
It does seem to me like cbrom is acting weird with this ROM. Not only it's reporting weird file size like Ydee has mentioned, but it's also reports a bunch of zeroes in regards to the CPU ID part. For a ROM that works with AMD K6 it also reports zeroes, just a bit less of them.
So it's either a wrong version of cbrom, or it just doesn't support such an old version of Award. So far I've tried cbrom 1.10 (the oldest version I could find) and that version works even worse:
CBROM v1.10 Copyright (c) Award Software, Inc. 1995-1997 All Rights Reserved. […]
CBROM v1.10
Total compress code space = 18000h(0.00K)
Total compressed code size = 00000h(0.00K)
Remain compress code space = 08000h(0.00K)
But I guess unless I'm going to suddenly learn how to disassemble stuff, cbrom is my only option here, so I'll try other versions here. 😀
Just to make sure — it is okay that I'm using all these tools under DOSBox and not on a real machine?
MR BIOS catalog
Unicore catalog
Reply 14 of 37, by jakethompson1
It looks like your BIOS lumps all CPUs with a family=5 together. There is also a test whether the vendor is GenuineIntel, but looks like it only sets another bit if so.
There is also a code sequence: mov eax,2; mov ecx,eax; xor edx,edx; wrmsr. It appears MSR 2 is "parity reversal test register"--hardly seems right--on a Pentium, and undefined on a K6-2. Looking at the definition of wrmsr, writing to an undefined register might generate a GPF. I don't know whether this gets executed or not though.
Edit: using my hacked copy of PCem it appears this would indeed happen. I expect you will find the POST card to get stuck at c0.
Reply 15 of 37, by soggi
jheronimus wrote on 2021-10-25, 22:38:
He's talking about these lines:
Yes, 1.10 is also the earliest version I know and have...
There are also other/older BIOS editing tools, but actually I don't have the time to dig into that and I also don't think they'll work for you. 😒
BTW it seems like @jakethompson1 is the moving registers guy here...sounds more skilled than me. This reminds me of the hardware architecture exercise course at the university - registers on a Z80. 😉
kind regards
soggi
Reply 16 of 37, by Ydee
As Soggi writes - Cbrom indicates the compressed space size of BIOS 192kB. How could it fit into a 128kB EPROM chip?
Another oddity: the compressed code occupies 64kB of the 192kB according to Cbrom, yet the remaining available space is 0kB? Why not 128 kB, as it should?
Cbrom, I think, can't work with this BIOS, and it gives incorrect values.
Reply 17 of 37, by bakemono
The 1500 PCT-A BIOS image is 128KB but the first 32KB is blank, the 2nd 32KB mentions NCR 53710... is it a SCSI controller BIOS? After that appears to be an oldschool uncompressed 64KB Award BIOS, not the newer modular type. Ripe for disassembly and patching, if somebody knows what needs to change.
Are the requirements for K6-2 initialization code documented publicly? For instance, I guess MTRRs would need to be setup, which don't exist on original Pentiums. If people are gung ho about modifying BIOSs to add something like this, then finding/creating a stock piece of code that performs this initialization, so the code can then be inserted where it is needed, seems like a good place to start.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 18 of 37, by soggi
bakemono wrote on 2021-10-26, 18:05:
…the 2nd 32KB mentions NCR 53710... is it a SCSI controller BIOS?
Yes, NCR is SCSI. Back in the day it was integrated into most BIOSes. It was needed to use the cheaper NCR ISA/PCI controllers which have no own ROM unlike the Adaptec controllers for instance.
kind regards
soggi
Reply 19 of 37, by Roman555
I guess It would be easier to find out how BIOS Patcher by "apple_rom" modifies Award BIOSes and then to insert the patches into the targeted BIOS by hands.
P.S. And of course don't forget the best book about BIOS hacking
https://github.com/pinczakko/BIOS-Disassembly … jutsu-Uncovered
P.P.S. What will the Patcher do if the string *BBSS* is added into the BIOS manually ? 😀
