The K6-III build
Reply 20 of 33, by rcarkk
Chill out guys. It was just a funny comparison 😀
Baby AT socket7 - Pentium MMX 233MHz + 3Dfx Voodoo
Socket 8 build - Soyo 6FA + Pentium Pro 200MHz + 3Dfx Voodoo 2 12MB
PC Remake - Pentium III 450 + Matrox G400 16MB
The K6-III build
Reply 21 of 33, by AlessandroB
Absolutely, you certainly it was a compliment, in the film the killer had an incredible skill in detail, a skill so out of the ordinary that it never allowed him to be discovered. I consider this skill extraordinary and that is why it was mentioned. Obviously, no one kills anyone in the IT world.
Reply 22 of 33, by rcarkk
AlessandroB wrote on 2021-12-07, 14:02:
Ahahah, thats an over statement. Don´t want to be the false modest, but with patience, logic and a clear goal, the skills will appear. This is not that dificult, it´s time and trial and error.
The K6-III build
Reply 23 of 33, by AlessandroB
rcarkk wrote on 2021-12-07, 15:06:
as a boy they hired me in a computer shop because I had masterfully assembled a computer and I tell you that my computer was much worse than yours.
Reply 24 of 33, by Intel486dx33
AlessandroB wrote on 2021-12-06, 19:15:
I have noticed now that even the button battery has the writing exactly aligned with the horizon
Yeah, This computer is aligned with the Pyramids of Egypt and constellation Orion.
Reply 25 of 33, by rcarkk
Intel486dx33 wrote on 2021-12-08, 02:45:
Thanks. That´s motivating to try to get better
The K6-III build
Reply 26 of 33, by Joakim
Would you mind describing how you made that sexy cable management? It looks like you have a cardboard or something that you wrap the cable around with cable clips?
If I ever decide upon a first final system I might copy the style..
Reply 28 of 33, by rcarkk
Joakim wrote on 2021-12-08, 16:01:
Yes, i used dual sided, glued cardboard, but im planning to use other stronger material. I use trial and error to seek the best geometry and dimensions for folding the cables. I use braces to do the trial and error. When i find the right form, i cut them and redo the cardboard structure. I finish using very strong scotch tape to glue the cables and cardboard and apply braces if needed specifically. Nothing special, only work and patience.
    901.29 KiB
    811.31 KiB
    821.91 KiB
    833.16 KiB
The K6-III build
Reply 29 of 33, by rcarkk
Batyra wrote on 2021-12-08, 16:09:
I love this clean look and super socket 7 too! Really nice!
Thank you 😀
The K6-III build
Reply 30 of 33, by Joakim
rcarkk wrote on 2021-12-08, 16:48:
Cool thanks for the guide. Yes, maybe some plastic material is optimal. Cardboard might not age well as it tends to suck up moisture.
Reply 31 of 33, by rcarkk
Joakim wrote on 2021-12-08, 17:06:
Will gladly help, if you need
The K6-III build
Reply 32 of 33, by AlessandroB
it is not a joke, it is in these details that you can see the very high level of the work performed. A masterpiece.. absolutely a masterpiece...
Reply 33 of 33, by rcarkk
AlessandroB wrote on 2021-12-09, 14:19:
Some people don´t care about those details which i understand. One year ago, i didn´t care that much about cable management. Now, i need to do the work as good as possible to be satisfied with the build. There´s no other option.
The K6-III build
