First post, by stealthjoe
Have recently bought a via based socket 370 motherboard (M6VLR v 3.0) with onboard audio and video. I installed win 98 and then was able to successfully install the via chipset drivers as well as the vga drivers. Now the problem is with the onboard audio (VT1612A IC).
While trying to install the via audio drivers, none of them worked. Tried installing Avanace_45 win 95 driver, Avanace_510 win 98 driver, VT82C686X_4 (R1 WDM) driver, etc, but in vain. After installing the win 95 driver, was only getting a cracking sound. The speaker icon is present on the task bar and the device manager shows the installed drivers for Avanace, but audio is not working. Also tried installing the dos driver under pure dos mode, but no sound as well. I am assuming this to be an issue with the onboard audio itself (IC probably). But surprisingly the device manager does not show any errors/conflicts. It was able to install all the drivers including SB emulation successfully.
Any thoughts on the cause for the issue? Thanks!!
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98/XP
