Reply 20540 of 31213, by kolderman
AppleSauce wrote on 2021-12-22, 02:39:
Im Finishing up my janky dos build. Added an mu80 to the synth pile and a nec power vr to the pc. […]
needs more stack
Reply 20544 of 31213, by PcBytes
Kahenraz wrote on 2021-12-21, 23:47:
PcBytes wrote on 2021-12-21, 12:17:
Mmm, that 7200 repair was nice. Shame that I (very likely) threw my 9000 AIW away, would've surely loved to fix it using your techniques.
Please spread the word. If you're going yo throw these things away, there is probably someone here to who may be able to fix it or would otherwise be useful for practice.
For what it's worth, I'm not 100% sure if it was the caps. Oh, and not sure if I REALLY threw it away or just threw it into the closet and forgot about it completely. I said very likely because of the possibility of the RAM chips being dead, but not always the case.
I do remember soldering a few caps back but still had artefacting, so at that point it could have been BGA failure on the RAM, and I haven't had any card using BGA RAM ever come back alive after reflowing the RAM chips.
I'll look through my mountains of "trash" (in reality, it's just lotsa stuff - mobos, GPUs, MXM GPUs, and misc PCI/PCI-E/ISA cards) and check if I still have it and hopefully check up what's missing and what needs resoldering.
(believe me, I found cards I totally forgot about. One of them is a Winfast A6200 TD that I would love to see back in action after some repairing, knowing it has some short on the Molex connector.)
Reply 20546 of 31213, by Nexxen
Opened the box, took this pic, closed the box.
Filthy.
I have to make a tool to remove all the keys. This is going to take a lot of time.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 20547 of 31213, by TrashPanda
Nexxen wrote on 2021-12-22, 09:26:
Opened the box, took this pic, closed the box. Filthy. I have to make a tool to remove all the keys. This is going to take a lot […]
Filthy.
Thats ... thats a fuck ton of work right there, I would close the box too till I had enough scotch on hand to make it hurt less 😁
Reply 20548 of 31213, by appiah4
Keyboard restorations are my least favorite kind.. I still have a mechanical Dell I can't bring myself to clean..
Reply 20549 of 31213, by Kahenraz
PcBytes wrote on 2021-12-22, 08:03:
I don't know the science behind it but even Louis Rossmann says that reflowing a BGA chip will usually end up destroying it. I can confirm that I've seen reflown joints fail again with time (weeks or months later). It's best to remove, clean, and apply fresh solder whenever possible.
Reply 20550 of 31213, by Nexxen
TrashPanda wrote on 2021-12-22, 09:41:
Filthy.
You understand my pain, a relief! 🤣 🤣
Gonna do in 2022. Starting with the working ones.
I'll try to retrobrite with the basin method. Cream leaves traces and they don't come off, I guess because of uneven layer.
Reply 20551 of 31213, by hyoenmadan
Kahenraz wrote on 2021-12-22, 10:28:
Because the type of solder used was prone to crack in the first place (too hard RoHS buggy formulations). Reflowing will not change that physical fact, and keeping the mechanical stresses of the faulty solder balls would end destroying the BGA pads on your chip.
When you clean and reapply solder to the BGA packages, generally you will change the solder to newer formulations, or even to non-RoHS solder, to fix the problem at its roots.
Reply 20552 of 31213, by snufkin
appiah4 wrote on 2021-12-22, 09:24:
Kahenraz wrote on 2021-12-22, 05:41:
TrashPanda wrote on 2021-12-22, 04:32:
Are there bbs still operating?
Yes there are. 😀
Over land lines? I know Telnet is still a thing but are there even real landlines left?
Did a quick Google and found this for the UK:
https://www.icuk.net/broadband/dial-up-internet.asp
And now I'm wondering whether to give that a go over Christmas. Got an external 56.6 and an ISA Zoom 14.4 (BABT Approved! I think) somewhere. I've a vague memory of the last time I tried using dial up (many years ago, DSL connection died) that lots of websites just didn't work because of time-outs. I think the rough expectation at 14.4kbps was about 10min/MB. BBC homepage is currently about 3.6MB. So that'd be over half an hour. About 3MB is scripts, images and fonts. It'd be 5min just for the HTML.
Reply 20553 of 31213, by appiah4
snufkin wrote on 2021-12-22, 12:30:
Did a quick Google and found this for the UK: https://www.icuk.net/broadband/dial-up-internet.asp […]
Yes there are. 😀
https://www.youtube.com/watch?v=17zfz017s9A
Reply 20554 of 31213, by TrashPanda
appiah4 wrote on 2021-12-22, 12:40:
Oh my .. that modem chatter, is it wrong to be happy to hear it again ?
Reply 20555 of 31213, by Kahenraz
TrashPanda wrote on 2021-12-22, 13:33:
Cathode Ray Guy also did a great video on modems too. He goes into it in depth more than would otherwise be relevant to computers specifically but I enjoyed it.
https://www.youtube.com/watch?v=OmBLsKV7Sx0
My retro activity for today was finishing the repair on my Midiman MM-401.
Diagnosing a broken Midiman MPU401
Reply 20556 of 31213, by TrashPanda
Well the Geforce 4 TI 4600 arrived today, the one that was artifacting from overheating and also had a bad fan, so I set about inspecting it and I could find no components that were missing or damaged so I set about removing the heatsink and as I suspected the TIM has gone super hard and brittle. Took quite a bit of effort to remove the heatsink without damaging the GPU, now I have to find something to remove the hard brittle TIM that remains.
Any suggestions since neither alcohol nor acetone had any effect on the TIM, I could gently scrape it off but im not sure how stable the surface of the DIE is.
Also anyone here ever rebuilt the small fans that come in the GF4 coolers ? it spins but doesnt sound great or spin fast, I think it might need a bit of grease but have never had to strip a fan this small down before.
Reply 20557 of 31213, by bjwil1991
I have fixed the GPU fan on my Ti4400 AGP by using sewing machine oil and white lithium grease, however, the fan died yet again and the fan connector totally ripped off on the fan itself.
You can use a case fan on the heatsink temporarily, however, the size of those things will prevent another add-on card from being installed, which can be problematic and using the regular fan is the way to go these days.
My recommendation is sewing machine oil and white lithium grease in the bearing shaft area (center of the fan underneath).
Reply 20558 of 31213, by AppleSauce
Kahenraz wrote on 2021-12-22, 04:28:
BitWrangler wrote on 2021-12-22, 03:21:
How is the phone wired into that? 🤣
How else is he supposed to dial into a BBS?
Ah man I wish I was around for the days of phreaking phones and stuff. I remember watching a BBS documentary where people they interviewed mentioned using 2600hz dial tones to get free internet.
Then they'd dial into a sketchy bbs to grab a copy of the anarchists cookbook.
Reply 20559 of 31213, by Kahenraz
Today I've been working on repairing a Voodoo 2. I've been carefully cleaning and reflowing the large quad flat pack chips and fixing other damage on the board.
