Acer 500+ ( MPF-PC/500 +E2 ) Gona try fire it up :)
First post, by _Roffe_
Hello
I have had a Acer 500+ (MPF-PC/500 +E2) in my basement for couple of years now and i finally started looking into starting it up and see if it works 😀
Iam typing this as iam looking for manuals/spec for this machine, and i found some material that is close to my setup.
https://forum.system-cfg.com/viewtopic.php?t=11979 (MPF-PC/500 +IIS2)
Info:
ISA Board:
CPU/500+ (N) 2L
PB87035-2
CPU: Sony-CXQ70108P-8 https://www.cpu-world.com/CPUs/V20/Sony-CXQ70108P-8.html
ISA Board:
Bios battery and stuff 😀
ISA MFM
Dose any one know anything about this kind of systems? 😀
Here is some pictures:
1.33 MiB
1.62 MiB
1.8 MiB
1.49 MiB
1.91 MiB
Reply 1 of 13, by _Roffe_
ISA Board:
CPU/500+ (N) 2L
PB87035-2
1.94 MiB
1.2 MiB
1.38 MiB
Reply 2 of 13, by _Roffe_
ISA Board:
1.16 MiB
1.29 MiB
1.39 MiB
Reply 8 of 13, by Horun
_Roffe_ wrote on 2022-01-14, 03:07:
Found this on the inside of the lid, dont know why i didn't check that the first thing 😀
That is great ! Over the decades only found a few old machines that had a similar jumper label attached inside the case.
That Sony cpu is a faster version of the NEC V20, very cool.
added: from what little info I found the 500 Plus used the Sony V20 cpu where the 500 standard used the Intel 8088-2, also a 8mhz cpu but lacked the the added new instructions from the 80186/80188 cpu's...
Will look for some docu's but doubt will find anything...
Reply 9 of 13, by _Roffe_
Horun wrote on 2022-01-14, 06:12:
That is great ! Over the decades only found a few old machines that had a similar jumper label attached inside the case. That S […]
This hole machine is cool in my eyes 😀
I always liked Acer laptops and this is by far the oldest Acer i seen!
Just need a MCE2VGA to try it out!
And then there is the keyboard that iam not sure if it is the standard AT keyboard? maybe 😀
And then i have 2 different graphics cards iam gona try upgrade it with!
A Hercules HGC
1.25 MiB
Or this random card, no ide what it is 😀
1.19 MiB
Reply 10 of 13, by snufkin
_Roffe_ wrote on 2022-01-14, 08:23:
If it's the 84 key, 10 Fn key version then it's probably based on the ModelF XT standard. It's not directly compatible with AT (although the connector's the same), but apparently some AT keyboards had a switch to put them in XT mode.
Reply 11 of 13, by _Roffe_
snufkin wrote on 2022-01-14, 12:33:
Have to look in to that! Might have a friend that have and old IBM at home..
What happens when you put ordinary AT keyboard in XT port? 😀
Reply 13 of 13, by _Roffe_
snufkin wrote on 2022-01-14, 14:28:
I don't think anything breaks, it just doesn't work. There are some converters to go from an AT keyboard to an XT machine: https://www.vcfed.org/forum/forum/vcwiki/vcwi … oard-converter=
Thanks!
Alot of converters needs to be invested in before a start up..
I want to do at least one start up before dishes and maybe open the PSU for a recap 😀
