First post, by gladders
I like the look of the Models 30, 50 or the 55 or even the 70 - the grills on the front of the case look really appealing. Only thing is I think the processors are at best only 386.
However the 486 models can obviously run OS/2 Warp 4. But I don't know if that's worth the upgrade. Plus the cases look less appealing - the Model 56 is alright but not as interesting as the others I mentioned.
Which would you plum for? Is the 386 perfectly good for PS/2 software, or would it be underpowered for the apps available for OS/2? Is Warp 4 worth holding out for, or is Warp 3 good enough?
Mind you I have an AMD DX100 and a Pentium III, I presume those regular PC clones can run OS/2 fine anyway? There's nothing in PS/2 hardware that can't be replicated on a PC, except for MCI (and who cares about that am I right?)
Which is your favourite case?
