power for an old serverboard
First post, by chris2021
It's common knowledge how to turn on an atx power supply, shorting the green wire to ground. But is this an advisable way to provide power to a mobi when you don't know where the power pins are? IBM 8682? Xseries 350 serverboard. I inspected the board last night, only 1 silk screened reference to "pwr...", but I think those pins are for a jumper setting. Nothing jumped off the pages of the hardware manual regarding how to turn it on.
Alternately I could attempt to determine wherd the green wire goes on the mobo.
This board has essentially the same 24 pin atx style connector as my Intel scb2 serverboard. I don't think I'm being overly presumptuous by plugging a nodern atx supply into that connector. It is not a standard board in any other way. The only other resemblance is that the i/o accessory connectors seem to be where they should be.
Reply 1 of 30, by PC Hoarder Patrol
chris2021 wrote on 2022-02-18, 00:10:
Suppose it might depend on how much control logic is built into the matching power backplane board (which I assume you don't have) - the system board may simply not be designed to power up directly without a number of BMC-style checks
Reply 2 of 30, by chris2021
There's a cpu diagnostic card or some such nomenclature I've seen reference to, the connector for which is very nonstandard. I had not realized a board of this vintage had such bmc hardware. Could that board be what you're talking about? I'll have to dig into the hardward manual more. But the manual is about a system not the serverboard itself. Which is a great disadvantage.
Reply 3 of 30, by PC Hoarder Patrol
chris2021 wrote on 2022-02-18, 00:58:
Don't see mention of a diagnostics card (tho the manual mentions the system board has built-in diagnostic routines). If you check the systems parts list - https://www.ibm.com/support/pages/system-part … ver-xseries-350 - and do a Google search for 00N6651, you'll see the part I'm referring to (it's common across a number of IBM servers)
Reply 4 of 30, by chris2021
Actually 00n6644 is my part. The system processor card. There's 1 on ebay. And ro think this project started w the ourchase of a 10$ motherboard 🙁
Reply 5 of 30, by chris2021
But the question remains is it an ok idea to force a mobo to accept power, any mobo. It doesn't seem like a terrible idea to me. But triggering a mobo is a result of a momentary contact. A p/s won't stay on unless you leave the green wire grounded, afaik.
Reply 6 of 30, by PC Hoarder Patrol
chris2021 wrote on 2022-02-18, 06:10:
Suspect most would prefer to have some form of 'sense check' before doing so - by manual details, trusted pinout definitions, experience of others, DMM values etc - but I'm sure some would jump right in (tho not me)
TBH, not really sure now what part (s) you have now...
- is it the full system board (00N6623) https://i.ebayimg.com/images/g/-Y0AAOSwfrJba0i4/s-l1600.jpg
- and the Advanced System Management Interconnect board aka the service processor card (00N6644) https://i.ebayimg.com/images/g/FuEAAOSw5WZalzro/s-l1600.jpg
or just the latter?
Reply 7 of 30, by weedeewee
Seems like neither of those will work separately, and the full system board will need a cpu module and memory module.
Do not ask Why !
Reply 8 of 30, by chris2021
Yes to both Hoarder's questions (didn't mean to call you a hoar).
I have the memory card. I'll buy the other card maybe today.
Reply 9 of 30, by PC Hoarder Patrol
chris2021 wrote on 2022-02-18, 09:51:
Don't forget you'll need a terminator card as well https://www.etiexpress.com/PartImages/DSC04952.JPG
Reply 10 of 30, by chris2021
No sir (or are you a ma'am?), I have 4 cpu's. May as well plug 'em all in once I give it some lightning.
Reply 11 of 30, by PC Hoarder Patrol
chris2021 wrote on 2022-02-18, 11:08:
Yes, last time I looked but nowadays who can tell!
and
Show off 😀
Reply 12 of 30, by chris2021
I never could tell frankly (or francinely). Can't even tell what you're affirming. Eh but what difference does it make. They'll just make it illegal to be yourself soon. Whatever that may be.
I'm not a showoff. I'm just thorough. Damned things weren't even 4 pops apiece. Weren't the 4 pops a musical group? Or was it 5 pops? Regardless was their theme gun shots or just celebrating they were dads?
Reply 13 of 30, by weedeewee
Report to your local denaturing office to be neutered and serve the elite as one of their eunuchs.
Do not ask Why !
Reply 14 of 30, by chris2021
I'll just put on a wig and dress. This way I can keep my blueberries intact. Oh wait I'm 6'4" 😳
Reply 15 of 30, by chris2021
This discussion leads me to wonder additionally what I'll need to operator my Intel quad lga2011 s4600lh serverboard. There is a module floating around out there, that I havent purchases, yet. It's funcrion is related to booting and/or securiry in some way. I forget the exact designarion, identiry module or something similar. I just may have to give Elon a call and get him to help me wire all this crappola into my brain. And then I'm totally sure it'll work fine 😉
Reply 16 of 30, by ODwilly
chris2021 wrote on 2022-02-18, 23:45:
TPM module? Those seem difficult to find for everything anymore.
Reply 17 of 30, by Horun
Yep have a IBM NetVista that has a tiny one (TPM module) similar to the ThinkServer and they are very hard to find OR very expensive if you ever needed one....
Although it can be disabled on my machine in the BIOS do not think you can on most server boards or maybe you can ???.
Reply 18 of 30, by chris2021
I could swear i saw them new on ebay. And I think it's use may be optional for the intel board but I won't swear to it at this very moment.
Reply 19 of 30, by Horun
chris2021 wrote on 2022-02-19, 02:14:
Very possible ! If you can get the board to boot without any HD's or network connections you might be able to disable data encryption (or it might be labeled something else in the BIOS) but yes I think you should be able to get by without if you can disable it in BIOS.
me neither ;p
