First post, by SamsungASUS
Hi, I had recently purchased a DFI Lanparty NF3 250 GB Motherboard and can't get it to power on or post. When I plug in the ATX Power Supply, regardless if it's in the 200 Watt range or 500 Watt range, it displays a red light on the motherboard like it's receiving power, but it doesn't seem to turn on at all. I've tried pressing the power switch on the motherboard and hooking up a case power switch, the motherboard doesn't turn on at all. None of the fans spin at all and the light remains red. I tried running it without the cpu, ram, graphics card, clearing the cmos, nothing turns on, including the fans, and there's no beep codes. I tried researching about this motherboard, but to no result.
