486 motherboard cache
Reply 21 of 32, by Disruptor
that's the reason why - auto configuration uses conservative timings
you now have a single bank configuration with 4*64Kx8 (UM61512)+ 32Kx8 TAG (UM61256)
please try a configuration with all 9 slots 8*32Kx8 (UM61256 / W24257) + 32Kx8 TAG (UM61256) populated (note: jumpers have to be changed to the third line in the manual) - this configuration basically allows tighter timings than the one with 5 slots populated
Reply 22 of 32, by Disruptor
with 2 bank L2 cache you may try and use 2-1-1-1 read burst at both 33 and 40 MHz and no write waits to L2 cache
and perhaps 0 / 0 waitstates for DRAM
with 1 bank you may need slower timings (2-2-2-2 or 3-1-1-1), at least at 40 MHz
Reply 26 of 32, by andy120
Got it to run at 40mhz on 2-2-2-2 wait 0. write back L2 is ok, but fails to boot on write back jumper for L1. Bios has it greyed out. The motherboards FDC chip was ripped off so i have to get a i/o card. a lot of the pads and traces are torn out. i have attempted relay the traces and pads but i cannot be 100% i have it correct.
Powered by one Harris 286-12
Reply 27 of 32, by Disruptor
You have PCICLK/3. This setting is for 25 MHz FSB.
Please use PCICLK/4 for 33 MHz and PCICLK/5 (if available) for 40 MHz.
I have no clue about L1 WB setting.
Reply 28 of 32, by CoffeeOne
andy120 wrote on 2022-03-26, 06:08:
for L2 2-2-2 non-interleaved @40MHz you need data srams with 12ns and tag with 12 ns according to the SIS471 datasheet, so it's good that it is working.
At 33MHz easily 2-1-1 would be possible, but 160MHz with 2-2-2 is for sure faster than 2-1-1 at 133MHz
Yes, L1 WB has to be defined via jumpers.
How did you set the jumpers 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32 and 33?
EDIT: typo corrected.
Reply 29 of 32, by andy120
per this except jp21 1-2 (2-3 does not boot) JP15 open, jp16 short, jp17 short (for 40mhz)
have to check 22, 30, 31, 32
    8.81 KiB
    No downloads
Reply 30 of 32, by CoffeeOne
andy120 wrote on 2022-03-26, 15:44:
🤣 I was looking into this manual:
EDIT: it is similar. Don't know. I was confused about your listing of JP10 and JP11.
So let's assume you have set it correctly.
Reply 31 of 32, by andy120
That was it!!!! 30 ,31 wrong way around!! freeking awesome!
many many thanks!!
    1.53 MiB
