Reply 220 of 288, by HanJammer
Adriand1281 wrote on 2022-05-22, 15:42:
Deksor wrote on 2022-05-22, 15:01:
Could you please take a picture of your board and send it to us, the one we have isn't very good (front and black if possible)
Of course.
If you are from Warsaw I can burn the chip for you.
Reply 221 of 288, by Adriand1281
HanJammer wrote on 2022-05-23, 15:26:
Of course.
No need, I have a programmer. But thank you for your willingness.
Reply 222 of 288, by evasive
Adriand1281 wrote on 2022-05-23, 14:54:
There is probably no separate thread for PGA370 boards, so I will post here. […]
Producer: Supergrace
Model: SG-810MATX3
Bios: Phoenix
PhoenixBios SG-810MATX3.rar
Relabeled PcPartner board:
https://www.ultimateretro.net/en/motherboards/7476
Reply 224 of 288, by arnovdheiden
arnovdheiden wrote on 2022-05-06, 09:16:
Okay I found some time to try this. But it didnt go as planned. I decided to upgrade from 10002cb0h to 10002cb0 first and upda […]
arnovdheiden wrote on 2022-03-16, 11:47:
evasive wrote on 2022-03-13, 19:32:
Hi Arno, […]
Hi Arno,
The only other way this is going to work is using the recovery flash method. You need an actual bios update disk and a floppy drive for that.
Power off, remove the only jumper on the board, put the upgrade diskette in the floppy drive. Power on. Now the nail-biting begins.
You need to wait for the beep of the system booting, the floppy starts reading. If all goes well, you will hear two short beeps. Then and only then, you can power off the system, put the jumper back and power on.
This is a good suggestion. I will try that in the near future 😀 thank you so much! very much appreciated.
I decided to upgrade from 10002cb0h to 10002cb0 first and update to 10006 after that. I made a bootdisk, copied the extracted files from the 10002cb0.exe
The system responded the way described, but suddenly the pc speaker produced a never ending series of low beeps. The FDD led was still on, but nothing was read anymore. I waited for like 10 minutes, but nothing happened. It's clear that te bios recovery failed. The board also didnt post anymore, the powerled is blinking and nothing happens.
Also made the rookie mistake to not save the current bios to the floppydisk before proceeding.
As you all can imagine I am looking for a CBoH bios to restore the motherboard to a working state again, using the bios recovery, but maybe someone has a better Idea I can try.
Found a working bios file 1001CB0H and the board lives again using the bios recovery. Result: I have an older bios now than I originally had. But hey, at least the board is not bricked 😀
Reply 226 of 288, by GigAHerZ
It would be absolutely amazing, if someone would have MR BIOS for SIS 85C471 based chipsets.
MR Bios docs tell that it exists, but i have not yet found it anywhere...
Filename   Port      Description  SIS 85C471
V089B410 SIS_410 4 Mem Banks, REG_6A=FF
V089B411 SIS_411 6 Mem Banks, REG_6A=FF
V089B412 SIS_412 8 Mem Banks, REG_6A=FF
V089B413 SIS_413 4 Mem Banks, REG_6A=00
V089B414 SIS_414 6 Mem Banks, REG_6A=00
V089B415 SIS_415 8 Mem Banks, REG_6A=00
NOTE: The versions above are but a few samples of the
many ingenious multiplex schemes possible with
this chipset. (Hint: try V089B410 first).
Reply 227 of 288, by kaputnik
Looking for an updated BIOS for the IEI SSC-5X86H VER:C ISA single board computer. Haven't been able to find any images online, but it seems like the SSC-5X86H was in production for years after mine was made in May 97 according to the QC sticker. Maybe later specimens shipped with newer BIOS versions?
Dumped the BIOS from my board with Awdflash 7.83, command: awd783.exe backup.bin /pn/sy
The flasher will ask for a file to program despite the /pn switch, but that will time out after a few secs, and it will go on with dumping the current BIOS.
Attached a zip with the dump from my board and Awdflash 7.83 in case someone has use for it/wants to dump BIOS from their board.
BIOS POST string: 06/28/96-ALI-1487/89-2A4KDD35C-00
Edit: Removed BIOS file temporarily, will reupload once I got a verified correct backup.
    263.28 KiB
Reply 228 of 288, by Horun
board #: 82 Re: 80286 BIOS image collection
Interesting old board. Looks like it had an option for a RAM card if the top slot parts were installed (to JE1, f1, g1 and h1, cannot think of anything else that would use that)
Reply 229 of 288, by Predator99
Horun wrote on 2022-08-27, 20:58:
Indeed, good idea with the RAM card.
I was not able to find a 286 board with a "SOLUTIONS" chipset on theretroweb.com. But the BIOS says its for "NEAT chipset". So its most likely a C&T clone. Maybe like this one
https://theretroweb.com/motherboards/s/unknown-neat-286
Reply 230 of 288, by Horun
Predator99 wrote on 2022-08-27, 21:33:
That is as exact as could possibly be. Good thing it can run the SIPPS w/0 the DIPS according to MTL doc.
Yep those 82c211, 212 and 215 are same code numbers for the CS8221 NEAT chipset. www.dosdays.co.uk has a reference to the "CS8221 SOLUTION CHIPSet"
Reply 231 of 288, by BreakPoint
What is the best way to dump BIOS from 80486 INTEL CLASSIC/PCI EXPANDABLE DESKTOP? Usually I dump directly from chip using universal programmer. But on this MoBo chip is soldered.
UPD. Problem solved. BIOS 1.00.05.AY0 already online.
My CPU collection - Looking for hardware in Ukraine - Ukraine vintage PC forum
Reply 232 of 288, by evasive
BreakPoint wrote on 2022-09-04, 18:39:
so are 7 and 8, nonetheless, thanks for your pictures.
Reply 233 of 288, by kendair
Hello Everyone!
I have a PCChips M570 V1.3 motherboard, and I'm looking for the original AMI WINBIOS. Upgraded the BIOS to the latest 09/04/1998, but I was dumb-dumb and not making any backups. Hoped for resolve some compatibility issues, but it get even worse with the new BIOS, now I cannot use any soundcard 🙁
I hope somebody have this board and can make a back-up form the original BIOS.
Many thanks!
Greetings,
Attila
Hungary
Reply 234 of 288, by HanJammer
Predator99 wrote on 2018-05-26, 06:25:
EGA Video cards - BIOS image collection
Can we have one for VGA (ISA/PCI) cards as well? I have some to post right away, and from time to time I'm looking for some less usual BIOSes too...
Reply 235 of 288, by bogdang
Hello, does anybody have a dump of the specific bios in the attached photo?
The motherboard is a really strange MSI-MS5124 socket 7 , but with a specific bios version (AMIBIOS AG76).
I have tried with all available bios files from the retroweb - SI3 and SI7 , rom files AG77 and AG79, with no luck.
It reads the image AMIBOOT.ROM from the floppy disk and then just an infinite sequence of 7 short beeps ... until I shut it down (I have waited for enough time, as long as 5 minutes).
Reply 236 of 288, by Roman555
kendair wrote on 2022-09-28, 10:58:
Hello Everyone! […]
Hello Everyone!
Many thanks!
Greetings,
Attila
Hungary
Hello,
Do you have a hardware programmer? BIOS update is a risky procedure.
There are some BIOSes preserved in web.archive.org. But it's difficult to say whether they are compatible or not.
Sybercom MB570
Amptron PM-9700
bns-computer PCChips M570 - just a list of BIOSes because of FTP links
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 237 of 288, by Roman555
bogdang wrote on 2022-12-06, 08:30:
Hello, does anybody have a dump of the specific bios in the attached photo? The motherboard is a really strange MSI-MS5124 sock […]
Maybe EEPROM is faulty so BootBlock can't recover BIOS flashing it from a floppy.
Or maybe there's a jumper on the mainboard that protects BIOS from flashing.
Sometimes a manufacturer (I don't mean MSI here) used one-time-programming (OTP) chips so it couldn't be recovered at all.
Reply 238 of 288, by Horun
Roman555 wrote on 2022-12-06, 22:17:
Maybe EEPROM is faulty so BootBlock can't recover BIOS flashing it from a floppy. Or maybe there's a jumper on the mainboard tha […]
Agree ! Hmm, If the flash eeprom is bad you will not be able to re-flash and have it work. How did you "brick" your BIOS ? or did it just fail on it's own ?
If you have an eeprom programmer (TL866 type) you can try to flash the chip, it will also help to find if the chip is bad.
Searching back thru archive org there never was a AG76 released/posted for MSI or Premio but there is a AMI AG77d bios (diff than the AG77) with AMI flash 5.3 which should work IF your bios chip is OK.
One thing: never load Himem.sys or other things to flash an old BIOS unless you know it is ok and always use the flasher tool that was meant to use for the BIOS version. Attached AG77d
added: the Chaintech 5SEM appears to have all same chipset/chips as the MS5124, will look to see if there is an AMI bios for it to try....
    AG77D.zip
    115.32 KiB
    37 downloads
Reply 239 of 288, by bogdang
Horun wrote on 2022-12-07, 02:31:
Agree ! Hmm, If the flash eeprom is bad you will not be able to re-flash and have it work. How did you "brick" your BIOS ? or di […]
I have checked, but there is no write-protect switch on the mobo (I managed to find the manual).
The bios was bricked during an eeprom update using AG79 (next time I will take into account the ID bios string too), the ami flasher was launched from a startup dos floppy without any extended memory manager.
I will try AG77d with the flasher, also from the floppy startup disk.
Thank you very much for your support!
