First post, by Susanin79
Greetings,
Recently I bought a nice Seagate hard drive, but the label seems incorrect as it pointed to different model, despite the fact that all warranty labels are in place and not damaged . The model number is Seagate ST41200N (model 94601-12G), and based on information from Stason here, it should be SCSI drive, but it looks like MFM or ESDI drive. I have tried to search images, looks similar and found this drive: Seagate ST-4182E (94166-182) ESDI 160 MB, the overall view and the connectors side looks the same.
I’d be appreciated if you help me to identify the correct model number using photos attached.
    597.31 KiB
    566.69 KiB
    593.25 KiB
    454.82 KiB
    374.94 KiB
Reply 1 of 5, by dionb
That's weird. The STxxxxxN drives were all SCSI and that's no SCSI drive, at least, the PCB definitely isn't. Could this perhaps be a transplant - someone took the logic board from a (dead?) ESDI drive like the ST4182E and stuck it onto a corresponding (formerly) SCSI physical disk?
Reply 2 of 5, by Susanin79
dionb wrote on 2022-06-27, 22:00:
All the cables and connectors from drive itself perfectly fitted to PCB, it looks solid. And STxxxxxN looks completely different, example: https://www.ebay.com/itm/125241044303
Reply 3 of 5, by Susanin79
OK, for the moment it looks similar to series Wren III.
and then, it should be one of this drives I suppose:
CDC (also see Seagate)
Formatted Speed
Model Number Capacity Cyl Heads SPT in ms Interface
94166-101 Wren III 84 969 5 34 18 ESDI
94166-141 Wren III 118 969 7 34 18 ESDI
94166-182 Wren III 152 969 9 34 16 ESDI
Reply 4 of 5, by pentiumspeed
This was CDC, not 1GB, nor SCSI or ESDI, actually around 80 to 100MB, MFM, I had worked on one of these back in the day. it should make LOUD "plonk!" I think when starting up to unlock heads.
Cheers,
Great Northern aka Canada.
Reply 5 of 5, by Susanin79
pentiumspeed wrote on 2022-06-28, 00:43:
Cheers,
Indeed, I have check with the photos in internet again and found that PCB from this SEAGATE 94155-86 has the same ID, so it is definitely 94155-XX Wren II series.
Unfortunately drive can not initialize the heads, after the several attempts it stopped the motor. Here is the short video with the opened drive. All heads looks OK.
    161.54 KiB
    301.4 KiB
