First post, by NScaleTransitModels
I finally managed to obtain such a motherboard, so I could try my luck at a 486DLC + VLB build.
It's a UTD 4700 ALL IN ONE, made by Up-To-Date Technologies (never heard of them): https://stason.org/TULARC/pc/motherboards/C/C … ALL-IN-ONE.html
It came with a 486DX2-66, which booted flawlessly. However, as soon as I installed a 486DLC and switched it into 386 mode, that's where the problems began.
First, it would get stuck on the "WAIT" boot screen. I had to disable "auto WS and bus clock set" and add a cache wait state.
It was still not stable enough to fully boot from floppy, so I had to disable the Fast Gate A20 Option (not sure what this does).
After that, I was able to install Windows 95, and run games + benchmarks. However, I ran into more issues when trying to install NT 4.0 (as a stability test). It would be unable to copy files at random, and always lock up before completing the last graphical phase. It was not truly stable.
A memtest revealed countless errors within seconds (should've done this first, guess my excitement got the better of me). I tried tweaking several more BIOS/jumper settings, swapping stuff out, but the only way I could get the errors to go away was to switch back into 486 mode. Then even a DX2-66 @ 80 gives no errors.
Here's what I tried to no avail...
Swapping out:
-486DLC vs. 386DX
-Memory sticks (4x4mb 60ns, tested fine on a different machine)
-S3 P86c805 VLB video card vs. Mach32 VLB and various ISA cards
-ISA Multi I/O card, disabling on-board IDE and floppy
BIOS settings:
-System Boot Up CPU Speed high/low
-External Cache enable/disable
-Internal Cache enable/disable
-Fast Gate A20 Option enable/disable
-auto WS and bus clock set disable
-Dram Read/Write Wait State, AT Bus Clock Selection, Cache Read/Write Hit WS, Burst Cycle WS— safest timings and basically all combinations
jumper settings:
-VLB speed <= 33MHz, 40MHZ
-CPU speed 33 mhz, 40 mhz
-CPU type: 80386DX, CX486DLC (just marked as CYRIX on silkscreen)
-limiting cache to 128k
In conclusion, the motherboard works great when I plug in a 486, but as soon as I switch it over to 386 mode, it becomes unstable. Did I miss any BIOS or jumper settings that might make a difference? Maybe a cap went bad? Any input would be greatly appreciated.
PS. 486DLC + S3 VLB benchmarks from when it was stable enough to boot into Win95:
-3DBench = 25.0
-Doom = 11.656 FPS
The attachment 20220627_215357.jpg is no longer available
The attachment 20220628_014853.jpg is no longer available
The attachment 20220628_014905.jpg is no longer available
The attachment 20220628_014917 (small).jpg is no longer available
The attachment 20220628_014935.jpg is no longer available
Builds:
  • ECS FX-3000; 386DX-40@50; ET4000AX, ISA 1mb
  • Acer VI9; 486DLC-40; Mach32, VLB 2mb
  • Chicony CH-471A; CX486s-40; Mach32, VLB 2mb
  • Gateway 2000 P5-60; Pentium-60@66; S3 928, PCI 3mb
  • DTK PKM-0033S; AM5x86-133@160
Reply 1 of 19, by rmay635703
I’m guessing memory timing or a bad chip
Have you tried an actual 386dx ?
Reply 2 of 19, by NScaleTransitModels
rmay635703 wrote on 2022-06-29, 18:31:
Yes, I tried a 386DX, a different 486DLC, and the jumper settings for 80386DX vs. CX486DLC. None of it made a difference.
I also tried all combinations of memory/cache settings, from 0-3 wait states. And multiple sets of 4x4mb 60ns modules.
Builds:
Reply 3 of 19, by Jed118
I too gave up on that dream - I had an EISA VLB 486/386 board, worked perfectly with the 486, would not take any form of 386 no matter what. At least you've got a manual for yours. I now have an IBM PS 1000 with a Blue Lightning chip in it 😁
My BIOS had (under advanced options) a "Enable 386" mode (or it may have said DLC too) - look around in there perhaps.
What's for sale? my eBay!
Reply 4 of 19, by NScaleTransitModels
Jed118 wrote on 2022-06-29, 18:58:
Man, sorry to hear. Seems some builds just aren't meant to be. When it comes to 386/486 VLB boards, I've already missed/lost several auctions, even had other buyers beat me to buy-it-nows.
Nice PS/1000, I watched your video on it just now.
No sign of "Enable 386" in the BIOS unfortunately. Perhaps it's a hidden option... if anyone on here has a ROM programmer, I could maybe send you the board to play with.
Builds:
Reply 5 of 19, by maxtherabbit
I'd like to kindly direct you to the listing for your board on The Ultimate Retro
https://www.ultimateretro.net/en/motherboards/1383
Please stop linking to stason. UR is a community project run by guys from this very forum
Reply 6 of 19, by jakethompson1
AT bus clock CLK2IN/6 is too fast I believe. CLK2 would be 66 or 80 MHz for a 33 or 66 MHz 386, so 11 or 13 1/3 MHz. You want CLK2IN/8 or CLK2IN/10 if you have those...
A 486 doesn't use the double-speed clock which might make a difference...
Reply 7 of 19, by jakethompson1
Hmm is it actually ok to jumper the board for 128K cache yet have all 8 chips in? I would make the jumpers match that it's 256K double bank...
Reply 8 of 19, by NScaleTransitModels
CLK2IN/8 is the lowest it goes. I tried CLK2IN/4 and /8, but it makes no difference. With either setting I can boot to Win95 and the sound card works (but memtest fails), so maybe they meant CLKIN instead of CLK2IN.
I tried both 128K and 256K jumpers, and enabling/disabling the cache in BIOS. Still failing memtest.
One option I haven't tried is Non-Cache Size Block and Non-Cache Address Block 1 and 2. The settings are 64kb, 128kb... up to 8192kb. Anyone know what this does?
Builds:
Reply 9 of 19, by Xeen
I always wonder if I can install 386 and 486 CPU at the same time and just use jumpers to decide which to use?
Reply 10 of 19, by rmay635703
Xeen wrote on 2022-07-23, 10:14:
That usually only works with a soldered cpu on a board meant to support
Otherwise
The attachment 7FCD8A9C-4CEA-43CB-9DCC-D88ACD75CEE1.jpeg is no longer available
Reply 11 of 19, by kixs
Installing NT4 on 386 is pretty optimistic by any standard.
Try adding a FPU for test.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 12 of 19, by jakethompson1
kixs wrote on 2022-07-23, 17:23:
I didn't think NT 4 ran on a 386 at all because of COMPXCHG. But maybe the uniprocessor kernel does?
Reply 13 of 19, by Xeen
rmay635703 wrote on 2022-07-23, 15:35:
That usually only works with a soldered cpu on a board meant to support […]
Otherwise
It seems the image is no longer exists, can you re-upload it?
Reply 14 of 19, by darry
Xeen wrote on 2022-07-24, 01:03:
Otherwise
It works fine for me .
Reply 15 of 19, by Xeen
darry wrote on 2022-07-24, 02:22:
Otherwise
It is working now 😀
Reply 16 of 19, by NScaleTransitModels
Update: I sold the mobo that was giving me problems (made sure to state "486 only"). Then by pure chance, I bought a mystery beige box, and opened it up to find an Acer VI9 386/486 VLB mobo. It already had a 486DLC installed, so I went ahead with the "NT4 killer test". No crashes, no errors, and memtest passes as well. Definitely doing a build around this one. I guess the other mobo may have had a design flaw (unconnected lines?) in its 386 mode.
Have actually tried this on a FX-3000 386/486 mobo. It wouldn't boot with CPUs in both sockets, but fortunately, no flamethrowers were manufactured.
Builds:
Reply 17 of 19, by NScaleTransitModels
jakethompson1 wrote on 2022-07-23, 18:50:
How do I switch to uniprocessor kernel? Is it an option during setup?
Anyhow, I've already done some testing of NT on 386-class CPUs.
NT 3.51: runs on 386
NT 4.0: no install, no boot on 386. Runs fine on 486DLC
NT 5.0 build 1906: Installs and runs on a 486DLC, but you have to be careful to not trigger CHKDSK, which will freeze at every boot.
2000: With 486DLC, BSOD "KMODE EXCEPTION NOT HANDLED" booting the last phase of setup. Have tried a few motherboards.
FPU made no difference in installation or ability to boot, but in NT5+, it is required for any sound drivers to work.
Builds:
Reply 18 of 19, by mr-spain
NScaleTransitModels wrote on 2022-06-29, 17:45:
I just won one of these on an auction, and it has some battery damage and a missing chip on the top left of your image, near the ex-battery location and KB connector. Could you do me a favor and take a more detailed pic of that area so I can read the chip and look at the traces? Much thanks!
Reply 19 of 19, by mr-spain
ahhh, you sold it. there goes my reading comprehension
