First post, by Alistar1776
So I have an old Gateway, my Win98SE system, that I want to upgrade for gaming. My most demanding game recommends a P4 or equivalent 1.6ghz processor. what I have is an AMD Athlon 850mhz which is barely minimum spec for the game. Im curious if theres a possible upgrade that can be swapped in?
Its a Slot A board, chipset is AMD-756ACD 9937CQC. Id like to do a video card and memory upgrade also down the line, I think this is the better place to start atm.
Thanks for the help as always!
Reply 1 of 5, by PD2JK
The best CPU would be the 1 GHz Orion or Thunderbird, both are supported by the chipset, but a BIOS update might be required.
However, I would say that the extra 150 MHz wouldn't be very noticable I'm afraid... And don't look at the absurd prices asked on eBay...
For a VGA card, see if you can get a GF4 MX440 or a Radeon 9000 or 9200 for cheap. Or hunt a more exclusive GF3 or 8500 down. 😉
Reply 2 of 5, by Alistar1776
PD2JK wrote on 2022-07-30, 21:15:
I previously had an 8500 LE id bought a month and a half ago, that kicked the bucket shortly after. Its running on a Geforce TNT 2 i think atm, not near enough card for the games. If i could do a socket 370 conversion, I wonder what processors could work then? Ive seen some people use those little conversion boards
Reply 3 of 5, by Sphere478
A slocket would be cool.
Sphere's PCB projects.
Reply 4 of 5, by PD2JK
Maybe you can design one. Never seen one, I doubt they exist.
Slot A is just a reversed Slot 1 connector, and the 750 chipset supports an Athlon 1400B... 😉
This is the only picture I could find. Never went in mass production. It was from NMC-PC.
    8.48 KiB
Reply 5 of 5, by chinny22
I've a Slot A PC with a 600Mhz CPU. I'd love to upgrade as already own a number of Slot 1 rigs stuck at 600Mhz but cant justify the cost of the higher end Slot A CPU's.
Slot A isn't that common, even AMD ditched the platform pretty quickly. I'd just enjoy the PC for lower end 9x and even dos gaming if that interests you.
