First post, by omarsis
I just found this socket 7 board with the Philips logo on it and I want to know what computer it came with. At least a picture of the case if anyone has it.
I tried Google but not many good results.
The one thing I could figure out is that it says 586STE/P and I figured out that there is a DFI motherboard named 586STE. Probably the /P is for Philips and DFI licensed that board.
I also look in this Wikipedia entry and it seems that Philips never made Pentium 1 computers "officially" https://en.wikipedia.org/wiki/Philips_Computers
1.03 MiB
1.12 MiB
1.1 MiB
1.36 MiB
Reply 1 of 8, by Sphere478
What a odd board..
What cpu was in it?
https://www.ultimateretro.net/en/motherboards/1748
Sphere's PCB projects.
Reply 3 of 8, by DerBaum
If i look at the discoloration of the plastics, it probably had a pretty hot life in a small case.
Maybe it was some kind of computer / recorder for a camera security system, or a cash register?
Philips made a lot of professional stuff.
FCKGW-RHQQ2
Reply 4 of 8, by Sphere478
It appears to have a dual plane voltage. So a k6-3 non plus may work in it but it’s kinda iffy with linear regulators and a minimum of 2.7v which is kinda high for a k6-3. a 3 plus will definitely require voltage mods.
The ram, physically 512mb will fit in it. But wether or not it is supported is another matter. Will depend on board/chipset.
With a k6-3 you can reasonably cache 512mb
These may be of interest>
Re: Socket 5/7/SS7 (Voltage Interposer) Tweaker. (Beta)
DIY Bios Modding guide Jan Steunebrink k6-2+/3+ 128gb
Reply 5 of 8, by omarsis
UPDATE!
I could successfully dump the BIOS and loaded in 86Box and to my surprise it works! And there is a Philips logo at boot.
I replaced the BIOS in the emulated Rise R534F r534f008.bin for the new file and works
7.26 KiB
Reply 6 of 8, by Repo Man11
Looking at images of motherboards with the 5571 chipset, a heat sink on the northbridge was included more often than not, and yours has residual glue indicating that it once had one; I'd see if you can replace it.
Reply 7 of 8, by evasive
omarsis wrote on 2022-08-12, 19:37:
UPDATE!
Can you post the file in here so we can include it on The Retro Web/Ultimate Retro?
