First post, by kgreen
Hey all, does anyone have an Abit ST6 they would be willing to part with?
I've got 12 SL6BY PIII's who are begging to go past 166MHz, but I've had no luck finding this board for years now.
Cheers,
~Kellen
Cheers,
~Kellen
Have you considered the Asus TUSL2-C? Should be in the same ball park.
Asus TUSL2-C is pretty much go to board for that task. Usually with no need for recapping, unlike Abit.
I own a TUSL2-C, however the FSB range stops at 166, unless there is a BIOS mod I'm unaware of.
It should go over 200.
It would seem that the 166MHz FSB limitation on the TUSL2-C only comes up when running CPU:RAM ratios at 1:1. Moving to 1.33:1 allows for higher FSB's.
