First post, by jarcher1701
Hello. I'm hoping someone might be able to help with some queries regarding this ES1868F card.
1. Any ideas what model/make it is? I searched for the available reference numbers but I couldn't find anything.
2. The purpose behind the the 40 pin connector placeholder on the left. Is this an IDE connector? If I soldered in some pins, would it be as simple as connecting the CD Rom to it. The disk controller I currently have only has 1 40 pin IDE connector so this would be helpful.
The card seems to work well in the games I've tried so far. Doom sounds good, although it crashes after a few minutes of play for some reason. I have a 486 DX 33, so I doubt the CPU is getting too hot.
Thanks in advance!
