First post, by Sphere478
Post any benchmarks you like, but lets try to at least get 3dm 99/2k if you can.
Post your full system config including model numbers/versions of parts if you
can, OS, hardware, driver versions, hacks, tweaks, anything special.
Let the competition begin!
Sphere's PCB projects.
Reply 1 of 15, by 80386SX
Good idea, curious to see the results too.
These plastic staggered CPUs have always fascinated me.
Reply 2 of 15, by BitWrangler
Not sure if there is one to find in the pile or not. Had a brief mention of an MP6 200mhz in some old scribbles, but it was in context of somebody else's machine I was fixing/upgrading, so not sure if I booped them up to k6-2-400 and dropped it in a box of junk or what. What I am a little surer about is I got an eBay lot of 6 new K6-2 400s, and swapped 4 of them into fam/friends machines early-mid noughts, ending up with two cyrix, one K6-233 and the fourth is in question. I have been able to reconcile about 90% of my ancient scribbles so far, the rest IDK if they will get explained eventually or not.
Reply 3 of 15, by Jasin Natael
Let's see those Rise/idragon scores!
Reply 4 of 15, by debs3759
When comparing CPU benchmarks, it's probably best to use a CPU benchmark, rather than a GPU benchmark with no specific GPU 😀
Reply 5 of 15, by Sphere478
debs3759 wrote on 2022-09-25, 18:00:
In the aiming for the stars threads we have been usually doing quake and 3dmark stuff.
You can post whatever you like though super pi? Prime? Sandra? Cpu-z mark
Reply 6 of 15, by Jasin Natael
Dang, I guess these chips are pretty rare.
I was sure at least a few members would have one and be willing to throw up some benchmarks.
Reply 8 of 15, by lukas12p
Rise 200 MHz (2x100), MVP3 2MB, GF2GTS
Reply 9 of 15, by pentiumspeed
Compared to what other processors?
Great Northern aka Canada.
Reply 11 of 15, by Jasin Natael
lukas12p wrote on 2022-11-11, 23:19:
Awesome.
Requisite: "it has begun...."
Reply 12 of 15, by jasa1063
I just put together a system with a Rise iDragon (MP6) PR266 @200MHz. I am using a PC Chips M585LMR motherboard. Not a top of the line motherboard, but I got it cheap and it has the very handy CPU Plug-n-Play in the BIOS setup. It makes trying out different speed combinations much easier. Anyway here are the results I got using Speedsys 4.78
Reply 14 of 15, by jasa1063
I overclocked my iDragon to 250MHz with a 2.5x multiplier and so far it's been stable. I am also attaching the datasheets for the Rise MP6 & iDragon CPUs and Speedsys 4.78 results to compare to my previous post.
Reply 15 of 15, by Sphere478
Got some new additions to the collection today :p IDK if I will bother testing them though unless someone thinks they may hold some secrets or performance I wasn’t able to see on the socketed cpus in the pic (the ones I already had)
Did ES cpus have any extra features or quirks?
