Reply 20 of 31, by badmojo
- l33t
The DOS software for that card is pretty shite, maybe the Win 3.11 drivers where likewise neglected? It's more of a Win9x era sound card in my mind.
what changes to system ini did the installer do? especially that mentioned file, where does it reside? any info from docs what it does?
wrote:The DOS software for that card is pretty shite, maybe the Win 3.11 drivers where likewise neglected? It's more of a Win9x era sound card in my mind.
It does seem more like a Win95 era card. Are there some other drivers you recommend?
wrote:It does seem more like a Win95 era card. Are there some other drivers you recommend?
No I don't I'm sorry - I've tried a couple of different versions to see if there's a better version for DOS but they're all pretty much the same.
For a nice sound experience in Windows 3.11 I go with a PAS16, which has fantistc software.
I looked those up on eBay - they are $100? Jeez! Not really worth it for just a test bed. My regular system has an ESS AudioDrive, which is fine enough. I am just wanting to run some tests with various DLC/SXL CPUs and various motherboards w/SCSI and sound to determine what the limitations are for each motherboard in this regard. I have an AWE64 Value I could try instead. There's also a vibra or two hanging around.
This thread shows how you can use Mediatrix software with the YMF71x cards to initialize:
wrote:This thread shows how you can use Mediatrix software with the YMF71x cards to initialize:
Isn't that only the DOS drivers? My issue is with the Win 3.11 drivers. I can use the Audican32's DOS drivers in DOS.
I abandoned the YMF718-S for a Vibra16, which is good enough for a test bed. All systems go. Not sure of the cause of the Audican's incompatibility with this board.
For those who still looking for solution, I followed the instructions on this page and it fixed the issue:
https://support.dynabook.com/support/viewCont … ontentId=107632
It seems that Yamaha software GM driver in Windows and Windows network stack overlap in some address range and can't get along.
So the trick is to disable soft GM.
I even had this issue with 36 MB of RAM. Memmaker didn't help neither disabling EMM386 .
terryfi wrote on 2021-10-08, 01:14:For those who still looking for solution, I followed the instructions on this page and it fixed the issue: https://support.dynab […]
https://support.dynabook.com/support/viewCont … ontentId=107632It seems that Yamaha software GM driver in Windows and Windows network stack overlap in some address range and can't get along.
So the trick is to disable soft GM.I even had this issue with 36 MB of RAM. Memmaker didn't help neither disabling EMM386 .
Thank you. The information in that link would have the user do the following within the system.ini file:
1) delete DEVICE=VSGM.386 [I think you can also comment it out with a semicolon ;]
2) change CPLMPUBoth=0 to =1
3) change DelSoftSynth=0 to =1
Indeed, this let me boot into Windows 3.1 with my SXL2 and an Audican32 card, however I was unable to play a wave file. Simply no sound comes out of the speakers and no error is produced. On the other hand, midi files play fine. Did you run into this problem?
As far as I remember I did not run into any other problems. I was able to play MYST with working audio and video.
feipoa wrote on 2022-09-29, 07:56:Thank you. The information in that link would have the user do the following within the system.ini file: […]
3) change DelSoftSynth=0 to =1Indeed, this let me boot into Windows 3.1 with my SXL2 and an Audican32 card, however I was unable to play a wave file. Simply no sound comes out of the speakers and no error is produced. On the other hand, midi files play fine. Did you run into this problem?
feipoa wrote on 2016-12-02, 01:10:wrote:This thread shows how you can use Mediatrix software with the YMF71x cards to initialize:
I know this is a very old thread, but I ran into this problem with my rebuild of a Retro PC using a Vaio PCV-70 motherboard and trying to make a "small form factor" retro PC using the onboard sound and video from this system. In Dos, the onboard OPL chip works pretty flawlessly, if not super high quality (as others have said) but in Windows, the Sound Blaster 1.5 drivers that come with WFW do not support the MIDI playback, and any attempt to play MIDI files froze the system, requiring a restart. Even basic games like OTWIN and SC2K would freeze the computer as soon as they tried to initiate MIDI playback.
It's a little convoluted, but my solution was to install the SB 1.5 WFW default driver, then SB Pro 2 drivers for Windows, then remove the actual SB Pro driver, leaving the rest of the material behind, including its MIDI driver. As a result, WAV and MIDI both now play (again, not the BEST quality, but to relive Oregon Trail on Windows 3.11, it's very passable).
