First post, by Simmerhead
I've gotten around to testing my ASUS CUSL-2 Motherboard with a Pentium III 933MHz. Sadly I can't get it to boot. The CPU and case fans spins up for a second, then nothing.
After trying most tips and tricks I'm left wondering if my brand spanking new 400W PSU is the problem. Could it be a 5V problem?
Feu3o0yXEAMn3Pz?format=jpg&name=large
Simmerhead - Old is gold!
Reply 1 of 8, by Horun
Do not think it is the PSU. What BIOS version does the board have ? the 933 is supported with v1007 and up: https://www.asus.com/supportonly/CUSL2/HelpDesk_CPU/
Reply 2 of 8, by Simmerhead
Horun wrote on 2022-10-11, 00:50:
I haven't gotten into the BIOS, so no way of knowing, but the board came with the CPU installed and had been functioning for many years, so it is compatible.
Reply 3 of 8, by Nexxen
Check V on VRM module.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 4 of 8, by stef80
Pic of the board? These boards are known to have a pattern of 3 bad caps near the socket.
Reply 5 of 8, by Simmerhead
Please let me know if you can spot anything obvious. Thanks!
FezjP2xXgAAg-4m?format=jpg&name=large
FezjViiXEAUKryF?format=jpg&name=large
FezjWEAXEAc8B4G?format=jpg&name=large
FezjWhfXwAAxyJj?format=jpg&name=large
FezjW__XEA4XJpW?format=jpg&name=large
Reply 6 of 8, by majestyk
The two electrolytics in the top right corner might be defective. They look a bit bulged in the 1st picture, in the second they look o.k.
The others are *looking good* - this doesn´t mean they are still ok.
Neverthetess I would recommend testing with a known good PSU first, before thinking about replacing the electrolytics.
Reply 7 of 8, by Nexxen
I visually checked all CUSL2 models and they all have the same board with different options,
- VGA no AUDIO, CUSL2; https://theretroweb.com/motherboards/s/asus-cusl2
- AUDIO no VGA, CUSL2-C; https://theretroweb.com/motherboards/s/asus-cusl2-c
- AUDIO and VGA, CUSL2-M; https://theretroweb.com/motherboards/s/asus-cusl2-m
If it helps.
Reply 8 of 8, by Nexxen
majestyk wrote on 2022-10-11, 17:43:
Absolutely.
Also check if there is any V out of the VRMs with the correct voltage.
Describe in detail what happens when you power it on, beeps, fan?
Troubleshoot needs details 😀
