PGA132 rotator boards
Reply 20 of 116, by feipoa
Why is this much more involved than the SXL2 interposer? Seems like the worst case would have you increasing the PCB footprint, up to, but not larger than, the SXL2 interposer.
Reply 21 of 116, by Sphere478
On the other interposer only Like half of them had to go across the board. on this one all of them
My fear is that there’s going to be so many traces and vias that I won’t be able to do floods which is going to make it even harder
Another thing is that on the last interposer we were able to take them across the board using only one or two layers and none or one via for most this design I fear I will have to use all six and as many vias (which protrude to all layers) for every single trace
I am not going to say that it is impossible yet but damn
I think I might actually have to use blind vias here for the routing and smd pads for the sockets. It is the only way this is making sense in my head
Sphere's PCB projects.
Reply 22 of 116, by feipoa
Maybe a 2-PCB approach is better for this application. Blind vias would demand use of PCBWay and the prices observed for PCBWay was prohibitive.
Reply 23 of 116, by Sphere478
feipoa wrote on 2022-11-06, 17:54:
Try the bodge wire in epoxy idea. (Basically like that table I showed)
I’ll play with the pcb idea when I get in front of a computer.
Reply 24 of 116, by feipoa
There would be very little benefit from trying a bodge, or wirewrap approach. I would need to use a side-by-side protoboard. This was tried previously on a 386 class CPU and was a failure above a 16 MHz FSB. Recall,
450.05 KiB
Reply 25 of 116, by elbbar
I thought this was an interesting idea, so I plugged it into eagle to see what it would do. If you just rotate the pins and hook each one up then it can easily route in 4 layers. It will also route in 2 layers, but the board needs to be bigger. Using surface mount parts is probably how I would do it, but I also tried a thru-hole version with the grid shifted over. I don't know how hard it would be to assemble this, but Advanced Interconnections makes a variety of parts that could probably make it possible.
I was not sure on the pin grid pitch so I used 2.54mm and used your picture above to get the 132-pin arrangement. This was just to see if it could work, so there are certainly tweaks that could be made to the design rules to put in more copper, etc. There could also be improvements by going through the specific pinouts, but another possible advantage of routing/rotating all 132 pins is that there is no "Pin 1" and with the shifted pin pattern you could also rotate the adapter to both shift and rotate the chip as desired.
33.26 KiB
81.68 KiB
60.3 KiB
Reply 26 of 116, by Sphere478
Beautiful!
2.54 is correct I believe,
Those nets look exactly like I visualized them.
The image is kinda small on my phone, and I am unfamiliar with eagle is that all connected? Do you intend on finishing this? Do you consider this just a draft or something you can tweak to compleetion?
I was imagining issues with too many vias everywhere to connect to the smd pads. I had intended on routing on the internal layers as much as possible but I suppose routing on the top and bottom would save a lot of vias for smd setup. 🤔
How do your floods look? Or will you need extra layers for it?
Being that the problem is so geometric, I was hoping for a symmetric solution a pattern to the routing ya know.
I agree that smd looks like the way to go from a pcb design standpoint
I also agree that maybe routing all of them and forgetting about power floods may be an option.
I would at the very least like to flood grond though. Perhaps there is a ground pin in a location that is equal on all 4 orientations
Reply 28 of 116, by elbbar
There may be an elegant symmetric routing for the surface mount version, but the shifted pin array version breaks it. One other advantage of the pin version is that the rotate left is the same board as the rotate right--just install the pins on the other side of the board.
I'm mostly just tinkering. I don't know the level of interest here, and the details depend on how it can be made. How much of a shift is actually needed for assembly? These guys might have some good ideas for actually making these adapters:
https://www.advanced.com/products/ic-socket-a … dapters/options
Sure a 12-layer board would be nice, but you can get 4-layer in small batches from places like oshpark. If that big stack of pin sockets will work, then a little rat's nest of traces might also. Here is a version that has wider traces and should meet oshpark's 4-layer design rules. I think the pin holes are 0.6mm, so it might depend on what size pins you'd want to install. Bigger holes take up room for wires...
81.39 KiB
Reply 29 of 116, by Sphere478
What happens if you only offset it 1.27 x 1.27y
This was my planned approach for a thru hole setup. Is it possible?
Yeah, my brain won’t be happy until I see something symetrical hahah 😂
Very nice work of course though. 😀
I’d be tinkering with it also but I’m on my phone away from computer still.
Reply 30 of 116, by feipoa
Are we sure the ground plane isn't necessary? The path lengths for the rotator board will have, perhaps, half the length of those from the unshielded prototype shown above and it was choking at low frequencies. There are, combined, 41 ground and Vcc pins. Wouldn't having Vcc and GND planes greatly reduce the quantity of traces needed? A 6-layer wouldn't be a show stopper, but 4 would be a lot more ideal. The through-hole approach is preferred so that anyone with the gerbers can assemble it with minimal soldering skills. On the other hand, elbbar is there a particular product you are recommending from Advance Interconnects which will allow simple assembly of 132 PGA pins via surface mount?
Reply 31 of 116, by elbbar
I shifted the pin version that way because it exposes most of the pins while keeping the board small. How would you build it if all the pins are covered? I don't know how I would do it, but it seems like there must be something to make it easier if surface mount is not desirable. I did see the solder preform idea. This would be similar to surface mount. Again, the details depend on how you plan to make it.
91.74 KiB
On the hand-made adapter, have you tried adding some bypass caps on the CPU socket? The power/ground pins are usually next to each other so you might be able to add little ceramic caps directly across pins on the CPU.
I think the 180 version would need more layers. This is a sort of worst case:
41.13 KiB
Reply 32 of 116, by Sphere478
^at that pic, 😵💫
Check out Feiopa’s other thread
Custom interposer module for TI486SXL2-66 PGA168 to PGA132 - HELP!
He figured out a way to assemble them.
feipoa wrote on 2022-11-08, 11:09:
Personally, I also would like to see a ground plane.
Reply 33 of 116, by elbbar
The 90 degree version can still route in 4 layers with a half-pin shift. If you wanted a ground plane you could make it as a 6 layer. Are the power and ground pins symmetric? Since you can plug the CPU in 4 different ways, it would be nice if it wouldn't fry when plugged in wrong.
72.03 KiB
The 180 degree version can route in 6 layers.
145.24 KiB
Reply 34 of 116, by H3nrik V!
Wonder if 180 degrees would be better achieved by stacking 2 90 degrees interposers?
Reply 35 of 116, by Sphere478
Here is the result of some tinkering I did.
So far so good. But more pins routed will tell the real tale of how doomed this attempt may be 🤣.
    1.69 MiB
Reply 36 of 116, by Sphere478
And more tinkering
    1.54 MiB
Reply 37 of 116, by Sphere478
Spent a while playing with this again. I swear there is a geometric way to set this up. there has to be a way other than spaghetti.
Reply 38 of 116, by feipoa
Are both sides surface mount? I'm OK to give that a go using solder paste. Double surface mount means 2-layer or 4-layer?
Reply 39 of 116, by Sphere478
I’m routing in 6 layer for my attenpt.
Yes, two surface mount.
Unfortunately this means every pad will have two vias beside it. I can cover them with silk though.
