Welcome back!
This Post:
This post will be about physically installing the tag ram PCB. This should be fairly straight forward but also very specific to the example motherboard I have to test with.
I'll be soldering the wires to the chipset not from the CELP slot.
BOM:
- Compatible sram chip x 2
- DIP28 narrow sockets x 2
- 1K through hole resistor x 5
- Some narrow Flexible wire
- 2.54mm pitch pin headers that will go into the socket of the first tag ram. The standard square ones are fine.
PCB:
I didn't take any pictures of the PCB going together. It is very straight forward though.
Solder the pin headers facing down.
Solder the sockets.
Solder the resistors.
After that I would advice installing the module so you can get your runs of wire right.
Northbridge solder mask:
I thought this part would have been more tricky than it turned out to be. It it just required patience and a dull hobby blade. I very slowly scraped away at the solder mask until I got a useable amount of copper exposed.
The traces on the chipset routed to the edge of the PCB but rather than aim for the edge of the PCB I aimed for the little tented via that I assume went down to the solder ball underneath. it gave me more work surface but I did have to be mindful while soldering not to upset the solder ball too much.
Note: while it looks like the traces from the chipset just flow onto the main board, they don't. I did have to double check and those traces go to different balls.
Image of uncovered via
The attachment IMG_20220531_195149356.jpg is no longer available
Northbridge wires:
This part is a bit tricky. Just have patience and a steady hand. Solder your wires to the chipset using some flexible wire. I used the very inexpensive wire wrapping wire you can find nearly everywhere at this point.
Dab your flux on and if you get any under the chip be sure to flush it out with plenty of IPA. I had stability issues that could have been from not flushing out the flux well enough in the first place.
After you get the wires on there, support them with something. I temporally used some Kapton tape while testing before going back and securing them better once I confirmed that the mod worked.
In my case I soldered my third wire to the edge of the pull resistor, just solder the wire to the TIO side of the resistor, not the 5 or so volts side. You will likely be able to just follow the trace from the chipset.
Image of wires on chipset
The attachment IMG_20220613_030824595.jpg is no longer available
All together now:
Now lastly we solder the wires to the PCB we added in. You don't have to solder the wires to the pads how they are labelled, I just added labelling because it makes me feel better.
You'll want to add support to the wires coming from the chipset, so in the event of a snag your mod is less likely to rip a trace from the chipset. Ultimately I coated the wires on the chipset with some curable solder mask and added a small bit of super glue to the wires over the motherboard. I don't like super gluing wires to PCB's like this but I thought it made sense here for the sake of pictures if nothing else.
You could use Kapton forever but I find it tends to come undone, or a drop of epoxy, your choice really.
Image of all together
The attachment cleaned.jpg is no longer available
A word about the sram
I know I used 15ns tag for the second tag ram it was just cheaper to get for the sake of the experiment. It works for the moment anyway.
Physically the mod is now installed. However we're more than likely not done yet.
Since these boards came with no option to install a second tag ram, the option in BIOS to set the L2 cacheable size is hard set to 64MB and you will need to modify your bios to enable 512MB
BIOS Modding
It's worth checking if you actually have to do this, just go to chipset features look for L2 Cache Cacheable Size and see if it lets you select that option for editing. If you can't select the option, or your can't see it, then you'll need to mod your BIOS.
It is a fairly straight forward bios mod as far as bios mods go.
Step by Step:
- Check out this video by Atheatos, he does a great job covering BIOS modding essentials.
- Look for L2 Cache Cacheable Size under chipset features.
- Set the "item-status" of that option to normal. It could be set to DISABLED or SHOW ONLY from factory.
- Save your modded BIOS as Atheatos shows you.
- Load up your BIOS on a programmer or if the board lets your flash.
- Set the option to 512MB.
- Save and quit.
Testing
To test if the mod has worked, you need to have greater than 64MB system ran installed, set L2 Cache Cacheable Size to 512MB in BIOS and run ctcm7 (attached to this post) from dos.
Look for "Cacheable Area L1" and "Cacheable Area L2", if those numbers are higher than 64MB then the mod has worked.
Personally I has 96MB of ram installed for testing this and you can see in my results screen that the mod worked.
Results:
The attachment results.jpg is no longer available
-Lime
Be Happy, it's only going to get worse.
- Projects
Limes Strange 3D models
USB-2-232
