First post, by rootinit
- Newbie
I found an AT 486 motherboard at an electronics resale shop with an included Intel A80486DX-33. I popped-in a 72-pin SIMM that I found elsewhere in the shop, and brought it home. Everything there is sold as-is, but I figured it was worth a try. I ordered an AT power supply, and inserted my Micro-Labs Ultimate VGA/TrueColor ISA card (Tseng Labs ET4000 graphics), which was working last I checked. I also swapped the CMOS battery with a new one.
Unfortunately, I got no video output, so I grabbed an ISA PC analyzer diagnostic card to get codes. It appears to stop at the "00" error code, which the manual tells me means the following: "Code copying to specific areas is done. Passing control to INT 19h boot loader next".
I believe that means it should be handing off to the disk's bootloader (no disk is here, since I have no controller card). If that were the case, shouldn't I still see some video? I wish I could troubleshoot with dip switch settings, but I have no clue what board this is (see attached images). I don't even know where to plug-in the PC speaker from the diag card. The only identifiable number that I can find on it is the following (which yields no search results on the web): 5320962-1RA0231962
Am I out of luck? What should be done next?
IBM ThinkPad 755Cs (Win 3.11) • IBM ThinkPad 365x (Win 98SE) • IBM ThinkPad TransNote (Win 2k)
IBM PC (PC DOS 3.30) • IBM PS/2 Model 80 (Win 3.11) • IBM PC 300GL (Win 98SE)
AT&T PC 6300 (MS-DOS 6.22) • Dell XPS T550 (Win 98SE)
