First post, by MrSteelrose
Specs:
Pentium III 933Mhz Coppermine (can be set to 466mhz with the clock speed multiplier if needed)
Geforce 2 GTS 64 MB AGP + voodoo 2 12 MB in SLI
AWE 64 value ISA
Windows 98SE
384MB RAM
i did some tests in dos mode (DOS 7.1) im using phils memory manager boot utility and the shortcut he made to boot properly into DOS
Might and magic III: goes super slow, one fram each 10th second or something and no sound
Wolfenstein 3d: all is working well with sound
Doom: everything is working good, i wish i could use the awe synth but im stuck with FM it sounds ok though
Lemmings1: all is well
might and magic 1: refuses to install says something about not enough memory or something
Tyrian2000: excellent with AWE synth music.
What should i do from here? how limited am i with this setup? any pointers on what to do to get the most out of this computer? in regards to DOS compatibility, windows gaming is all good.
Pentium MMX 200mhz. ati 3d rage2c + voodoo 1 64 MB SDRAM
Pentium 2 300mhz geforce 2 gts + voodoo2 SLI 256 MB SDRAM
pentium 3 933 mhz voodoo3 3ooo AGP. 256 MB SDRAM
Pentium 4 2.8ghz geforce 4TI 4200
Intel 3770 geforce 780
Intel 10700k Geforce RTX 3080
