Reply 47520 of 59832, by TheAbandonwareGuy
- Oldbie
Radical Vision wrote on 2023-01-06, 17:09:Got this ThinkPad T60 from trade (did give Cougar Speed mice pad).. It is with ATi Radeon x1400 and artifacts bonus..
Will gun down that crap artifacts with the heat gun, and see if will help... If not will use what i can to try to fix my 14 inch T60... Seems so far i have multiple laptops, and non is compatible with the other ffs... That being ThinkPad R60, T60 14", T61, T60 15"...
I can't recall if the X1400 is one of the models that uses system ram to supplement a small amount of onboard VRAM, but if it is try changing your memory out first.
