Reply 20 of 73, by douglar
- l33t
Here is what I've seen for Sata IDE Bridges
IDE Controller to SATA Drives
JM330 -- I don't have one of these
JM20330
IDE/SATA DOF
The performance between adapters using these chips was within the margin of error in my testing. (Tested using speedsys)
I've seen it implemented lots of different ways:
- 40 pin female to Sata cables
- 40 pin male to Sata connector
- mSata to 44 Pin Male
- M2 NGFF Sata to 40 Pin Male
SunPlusIT
SunPlusIT
I've only seen this in the plastic encased module that has 40 pin female, Berg power connector, Sata cable in, Sata Cable out
Performed 5-10% slower than the JM20330 or IDE/SATA DOF
For the DOMS, I've seen 2 controller chips:
SM223TF that supports up to UDMA4
EN2232T that supports up to UDMA6. Had some compatibility issues with some early EIDE controllers, but fine with original ATA or UDMA5 controllers
