Reply 23560 of 31262, by Nexxen
Sorting some new cpus.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 23561 of 31262, by kohellus@gmail.com
SteveC wrote on 2022-12-28, 19:20:
kohellus@gmail.com wrote on 2022-12-24, 11:28:
My new retro network build network. It serves something else too but 4 vlans, one for retro and other for various iot's and the rest for my home network. Nothing fansy but working. Pfsense and 4 gigabit ethernet ports. Works with everything for my retro nas serving drivers and os's, games 😀
What's the model of this HP PC?
Hi, its a HP T620 PLUS 4Core 4GB 16 SSD. It has a 4x pci-e in it so i stucked a HP Quad Port Gigabit Ethernet in there. Works perfectly with pfsense and fast enough for retro stuf.
Reply 23562 of 31262, by stef80
Tested and refurbished Nvidia's Fermi - Zotac AMP! edition:
The attachment 20230115_130027.jpg is no longer available
The attachment 20230115_141134.jpg is no longer available
The attachment 20230115_114224.jpg is no longer available
The attachment 20230115_114301.jpg is no longer available
The attachment 2.JPG is no longer available
Reply 23563 of 31262, by davidinark
I have been messing around with usb2isa-r trying to wrap my head around getting the isa controller to talk to my windows 10 (or separate xp) machine in order to read and write to the 5.25 inch floppy…
The attachment D610D46F-9891-4E96-9432-0856A055C8E6.jpeg is no longer available
I have a Greaseweazle v4, which works but you have to read to image, edit the image, then write the image back. I want to read and write directly.
Exercise in futility? Probably.
Reply 23564 of 31262, by Fizzo
pentiumspeed wrote on 2020-02-17, 01:55:
Tested again just to boot up in POST screen only on video cards that I had no luck using Micronics M55HI HX chipset based mother […]
Tested again just to boot up in POST screen only on video cards that I had no luck using Micronics M55HI HX chipset based motherboard. I got AN430TX Intel motherboard in the mail few days ago so re-did the PCI video cards that I have no luck booting up did work, all of them including TNT2 M64 and FX 5200 (128bit kind). 😀
AN430TX does allow me to jumper multi from 1.5X to 3.5X on both two mmx, 200 and 233, also regular pentium 200 which can do 100, and both pentium and also two mmx processors can do 133 as well.
And tested AN430TX to see if I can disable L2 cache (512K) and that L2 disable does works.
Will a utility that can disable L1 cache with these mentioned CPUs and this AN430TX motherboard? This is for DOS and some heavy games that 233mmx can handle?
Palette snooping turned on results in no post with S3 864 video card, had to switch back to another PCI video card and get in and disable palette snooping.
Cheers,
Hi, I just bought this Motherboard. Just checked on the manual it stated that the CPU supported are 166 and 200 mmx. Do you by any chance know if I can use a Pentium 266MHZ MMX (SL2Z4) on this board? Thanks.
Reply 23565 of 31262, by timsdf
stef80 wrote on 2023-01-15, 14:06:
Tested and refurbished Nvidia's Fermi - Zotac AMP! edition: 20230115_130027.jpg 20230115_141134.jpg 20230115_114224.jpg 20230115 […]
Nice card. I got one of these in a x58 PC too 😁 It runs really cool on the core but VRM heatsink it gets VERY hot with stock fan speed 1200-1800. It needs manual fan control 2000rpm+ to cool VRM even a little. I haven't used it much since it really needs some heatsinks on the backside of VRM too in my opinion.
Reply 23566 of 31262, by stef80
I ran Unigine for a while just to get feeling for the temps. Core is OK, seems programmed to keep it under 70°C. But memory/VRM heatsink is burning hot although it says 47°C for the PCB 😁 (well, It might be subjective). But yes, I'm surprised how silent it is.
Reply 23567 of 31262, by timsdf
PCB temperature sensor doesn't report VRM temp. No idea where that sensor is located. VRM gets 80-100c in couple min of stress with stock heatsink / airflow. This is a reason why I haven't used the card much without modding it (yet).
Reply 23569 of 31262, by Nexxen
gerry wrote on 2023-01-16, 20:42:
Nexxen wrote on 2023-01-15, 03:45:
think of the computing power you have there!
Yes, and the price tag too!
40+ P4 from 1.5 to 3.2 ghz! Thousands. Got them around 0.50€ with the chore of pin straightening.
All in working condition. 😀 Got lucky as hell!
Reply 23570 of 31262, by mrfusion92
I got my first AMD Socket A computer for free. It has a Biostar M7VIZ with a Athlon XP 1700+ and 1 GB of DDR ram.
It had a TNT2 M64 which I promptly replaced with a Sparkle Geforce 6600 GT AGP card, it has a red pcb just like the motherboard. Swapped old oem psu with new one for precaution, installed XP and now I have an average 2004/5 build.
On-board sound is a bit crap, what is best sound card for this PC a Sound Blaster Live! or a Audigy 2 ZS? I don't need dos compatibility.
Reply 23571 of 31262, by Shponglefan
Started my next project: to restore this Tandy 1000 TL.
Exterior-wise it's in reasonably good shape. Other than a broken volume knob everything else in intact.
Inside, the metal frame has a bunch of corrosion. So I think the first step will be a full teardown and rust removal.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 23573 of 31262, by Shponglefan
Ozzuneoj wrote on 2023-01-16, 23:36:
Nice machine!
Thanks! 😀
What do you plan on doing to treat that rust?
I'm going to try Evapo-Rust.
Haven't used it before so I'll see how well it works. But I've heard good things.
Reply 23574 of 31262, by Shponglefan
Did some rust removal on the Tandy TL using Evapo-Rust.
First time using this product and it worked even better than I expected. Since I was only using 3L of the product, I couldn't fully immerse everything at once. It took about a day altogether, rotating the pieces every few hours.
Reply 23575 of 31262, by Ozzuneoj
Shponglefan wrote on 2023-01-18, 15:26:
Nice job!
Are you going to treat the metal with anything now, or just leave it as is?
Reply 23576 of 31262, by Shponglefan
Ozzuneoj wrote on 2023-01-18, 19:05:
Nice job!
I'm going to leave it as is for now. I'll see how it holds up.
Reply 23577 of 31262, by Bancho
Re-housed my main Retro Rig (Via C3) into the Lian-Li today. Would like to maybe do some custom length wiring on the PSU.
Reply 23578 of 31262, by BitWrangler
Wow, monkey brain like "Am I supposed to throw rocks at it?" (2001 Space Odyssey joke)
Reply 23579 of 31262, by Bancho
BitWrangler wrote on 2023-01-20, 15:41:
It is kinda Monolithic looking!
