First post, by JustJulião
Well, not my PC itself, sorry if it looks like a clickbait.
A Molex to Sata adapter that was hanging in air, still plugged in the Molex. it's a PC I sometimes use booting Acronis to clone OS and disks. I was not using the PC for that purpose so the adapter wasn't in use.
It used to work without any issue. I didn't change anything and it happened suddenly while the PC was powered on since 5mins or so.
It made actual flames, I could hear it taking fire, but the PC seemed to work before I unplugged the PSU.
I didn't turn it on again yet.
I have no clue on what could have caused this, especially since it was not being used. Maybe something metallic stuck in the Sata port ? It would be strange anyways since it's hanging this way since weeks with the PC turned on sometimes all day long.
Not sure what to do now. Any advice ?
75.97 KiB
58.53 KiB
66.31 KiB
Reply 1 of 10, by konc
Yes, throw away these SATA adapters and buy proper ones. It's a known issue, give me a min and I'll find a reference on this forum of what a "proper" adapter is.
Edit: I found the photos I was looking for: Re: Power supply for 6800 Ultra OC AGP?
Reply 2 of 10, by JustJulião
konc wrote on 2023-01-17, 13:24:
Yes, throw away these SATA adapters and buy proper ones. It's a known issue, give a min and I'll find a reference on this forum of what a "proper" adapter is.
Thank you, it's "good" to know that it's a known issue with these. I was feeling slightly traumatized to be honest.
Reply 4 of 10, by JustJulião
Jasin Natael wrote on 2023-01-17, 14:05:
Did it at least "halt" first?
J/K, I have had this happen. Those adapters are terrible.
No everything was behaving normally besides the adapter taking fire.
Reply 5 of 10, by debs3759
Definitely clickbait (why would I click on a post about a dodgy cable?) 😀
Glad it wasn't plugged into a drive. Coulda been a lot worse!
Reply 6 of 10, by Half-Saint
holy crap. I've been using various sata-molex adapters for years any never had a problem. Maybe I've just been lucky.
Just took a look at my adapters and one out of three was molded. Maybe better to just throw it away.
Reply 9 of 10, by jmarsh
Maybe cheap and nasty metal used for the pins in the plug, that "splintered" and created a metal whisker when it got plugged into something. Think what happens when you put steel wool on a battery's terminals...
Reply 10 of 10, by chinny22
I like modular PSU's that way you can get the right connectors type direct from the PSU without any adaptors.
I will admit I do it for looks over safety reasons though.
